Chosing a set-up for my brother Evo Viii. Advice welcome.
Old Oct 13, 2011 | 08:17 PM
GG_EVO_IX's Avatar
Delete.
Old Oct 13, 2011 | 08:22 PM
sujinX's Avatar
might want to look at the deautsch werks (spelling??) fuel pump instead of the walbro. also get rid of the lower IC piping as its not optimal, expands under boost. manual boost controller should be added. some free flowing 3" exhaust like the buschur. something that doesnt neck down at the cat.
Old Oct 13, 2011 | 08:35 PM
ITOzann's Avatar
I want an FP green T.T
The Walbro 255 should be fine for those power levels. 1000cc-1050cc injectors if you are going to run pump gas; bigger injectors if you are going to run e85.
_A
Old Oct 14, 2011 | 01:04 AM
ChanseEvo8's Avatar
Registered User
gsc s2 cams and e-85. LOL
Old Oct 14, 2011 | 05:50 AM
thepoint4life23's Avatar
ported intake and exhaust manfold bigger throttle body
Old Oct 14, 2011 | 06:38 AM
ILuvJDM's Avatar
kind of off-topic, but the FP turbos are categorized based on power, correct?
Green is entry level, Red is a medium and Black is the high output?
Old Oct 14, 2011 | 06:44 AM
binky's Avatar
Yes, that's more or less correct.
You also have to think which of them is the best for your specific application.
For example, you have a daily driven Evo, you want some good power, but don't want the turbo to be to laggy, the BB Green might be a good choice.
-Bink
Old Oct 14, 2011 | 07:14 AM
ILuvJDM's Avatar
awesome, thanks
Old Oct 14, 2011 | 08:42 AM
Evo_Jr's Avatar
What fuel?
Old Oct 14, 2011 | 10:51 AM
Hardware's Avatar
What dyno?
Old Oct 14, 2011 | 11:19 AM
two203's Avatar
fuelpump + injectors + e85 tune thats it
Old Oct 14, 2011 | 05:16 PM
Playap07's Avatar
Veteran: Air Force
bushur Double pumper, gsc s2 cams, springs/retainers, arp head studs, e85 and 30psi of boost on a fp green and you will be golden my brudah!
Old Oct 14, 2011 | 07:17 PM
GG_EVO_IX's Avatar
Hey everyone, thanks for your input. Stuff like a double pumper ect are out of the question since he wants it to be a daily driver (5-6 days a week). The nearest E-85 station is an hour away so that's also out of the question as far as DD goes. He will have a tune for E-85 though just for the track. His set up right now is fulled of crap parts so I'm changing his set-up for him since he's too busy to research and do it himself.
What do you guys think about the MAP EF2 turbo? They also have the install kit as an option so that seems a little easier. Anyone running the EF2 out there?
Old Oct 14, 2011 | 07:29 PM
prowakeskater's Avatar
if he is DD'ing it, might as well stay with stock framed turbos
Old Oct 14, 2011 | 07:35 PM
GG_EVO_IX's Avatar
Fp green and Ef2/3 are stock frame.. Right now, I just need help finding the right turbo for his car and go from there.
