manifold removal.. help
Old Oct 14, 2011 | 01:23 PM
IraqFire88's Avatar
Veteran: Air Force
The nuts won't come off and there is no clearance between nut and manifold for a socket so I am stuck anyone else have this problem.... It's a buschur cast mani
Old Oct 14, 2011 | 01:30 PM
05blue8's Avatar
Are you referring to the nuts that hold the manifold to the head on the studs? Did you spray them down with pb blaster? There should be room for 1/4 deep sockets with an extension bar on there...
Old Oct 15, 2011 | 07:49 AM
FERNO's Avatar
This is dead on. I waited about 30 minutes after spraying PB blaster.
Now if you're talking about the outlet side, I had to use a stubby combination wrench for the passenger side rear nut. It was a bit of a pain.
Old Oct 15, 2011 | 11:37 PM
IraqFire88's Avatar
Veteran: Air Force
Yes on blaster there is absolutely no room for a socket and this is Jus on the top 4 ...I finally Jus cut the studs off but the 2 that did back out made grooves in the manifold from turning so close ill upload pics wow what a pita
Old Oct 15, 2011 | 11:54 PM
forc3 f3d's Avatar
Why would you cut the studs off?!!
There's room for every nut with a socket or a wrench. It's a pain, but you don't need to cut the studs
Blakesterone
Jan 27, 2017 05:06 AM
dayvidswrong
Lancer How Tos / Installations
Aug 3, 2015 02:25 PM
ebp99si
Jan 14, 2013 05:02 AM
omniprobe
Jun 6, 2011 01:10 PM
Solo Evo
Jul 13, 2005 10:50 PM
