what kind of coolant/oil/fruids?
Old Oct 18, 2011 | 02:28 PM
jym89709's Avatar
i just bought a evo 8.
i was wondering what kind of coolant/ engine oil/ mission oil/ diff. oil/ clutch/ etc i should use for this car...?
and where can i get front bumper plate braket?
Old Oct 18, 2011 | 02:38 PM
Piro Fyre's Avatar
Some will recommend Diaqueen. Others Redline. And of course, some Amsoil. I personally used Amsoil for my rear diff, transfer case and tranny. Castrol Edge in the engine. Peak for coolant. Exedy OEM replacement clutch. Just take some time to research an Evo, there's a ton of things you can do with it.
Also, if you need a front plate bracket, I have one. Just PM me if you want it. Dealership would be your 2nd option but god knows how much they'll charge for something like this.
Old Oct 18, 2011 | 02:41 PM
binky's Avatar
Hey,
I would use the following:
Coolant: PEAK Coolant (I use the coolant that's already mixed)
Engine Oil (Depending on the turbo that is on the car) For Stock Turbo: Mobil One 10W-30 with a Mobil One Filter
Transmission: I like BG Synchro Shift (some people will tell you this fluid is not the best, however I like it and never had a problem) Or Redline MT-90
Transfer Case: OEM Diaqueen
Rear Diff: OEM Diaqueen
Clutch and Brakes: Motul RBF 600
Check out http://www.mitsubishiparts.net/ for OEM parts.
-Bink
Old Oct 18, 2011 | 03:14 PM
ProPilot04's Avatar
This should probably be a good starting point. It's stickied right at the top of this forum.
https://www.evolutionm.net/forums/ev...uantities.html
Also, welcome.
gilevo7
May 20, 2017 10:55 PM
ahr4156
Sep 4, 2011 04:46 AM
striderx88
May 9, 2011 12:51 AM
brand0n
May 1, 2011 03:19 PM
awd_Boost
10
Jan 24, 2010 06:09 PM
