over boosting
Old Nov 3, 2011 | 07:02 PM
mikeywick821's Avatar
over boosting
This is probably a n00b question, but how do you know if your over boosting?
Im boosting 26psi right now. but when i got street tuned i only made 328whp 301 tq
it just seems pretty high as opposed to seeing other peoples graphs.
I could be wrong but im learning still
Old Nov 3, 2011 | 07:13 PM
sparky's Avatar
Originally Posted by mikeywick821
This is probably a n00b question, but how do you know if your over boosting?....Im boosting 26psi right now. but when i got street tuned i only made 328whp 301 tq....
You are allowed one or two n00b questions on here before they pull the plug on you. JK
Old Nov 3, 2011 | 07:19 PM
sparky's Avatar
91 octane, right? What gear are you getting that 26 PSI reading in? When you got your car tuned was it tuned for 26 PSI? Is this with a stock IX turbo? How is boost controlled(MBC, EBC, stock solenoid, or 3 port with modified ECU controlled boost)? Is the boost creeping up? That is, was it set at a lower boost level and now it is creeping higher?
Old Nov 3, 2011 | 08:22 PM
xXlEVOlXx's Avatar
here's another n00b question for you... wen over boosting, wouldnt you hit boost cut?
Old Nov 3, 2011 | 08:24 PM
Raptord's Avatar
If the tuner disabled the boost cut to not have to deal with it, no.
Old Nov 3, 2011 | 08:37 PM
xXlEVOlXx's Avatar
wow i was not aware that you could completely disable it. now is it possible to disable on a stock map? or would i have to get a tune?
Old Nov 3, 2011 | 08:44 PM
5speedwtneed's Avatar
It's more of delaying the ECU from responding to the over boost. Which could be near infinity =p
Old Nov 3, 2011 | 08:46 PM
Raptord's Avatar
On a stock map boost cut will be enabled. Getting tuned doesn't necessarily mean they'll disabled it; the proper way to do it would be to see how much load the car is seeing under normal conditions and adjust the boost cut to give a small margin for variances due to temperature etc, but still be able to protect the engine if something goes wrong.
Old Nov 4, 2011 | 12:12 AM
turbotalawd's Avatar
First off, what are your mods?
Pretty hard to give you an answer with just the info you provided.
Old Nov 4, 2011 | 12:59 AM
dang then I already exceeded my maximum lol
Old Nov 4, 2011 | 01:10 AM
yeah 91 octane on a stock iX turbo. im boosting 26 psi in 2nd, 3rd, and i believe 4th when im WOT. also its the stock solenoid
from my graph im at 25 psi @ 4000 rpm.
it just seems high compared to similar setups (+) cams and FMIC
Old Nov 4, 2011 | 01:11 AM
AMS TBE + test pipe
ETS LICP
FIC 1050 cc
walbro 255
fujita intake and UICP
stock ix turbo, stock solenoid
Old Nov 7, 2011 | 02:20 AM
Rmeister007's Avatar
What's the advantage of a 3 port solenoid?
Old Nov 7, 2011 | 06:22 AM
Raptord's Avatar
More precise boost control with ECU-controlled boost, possibility of using PSI-based boost control, gear-dependant boost control (with TephraV7), switch boost level with alt-maps (with TephraV7), IAT-compensated boost control so you don't have to mess around with your settings when winter rolls in.
The disadvantage is that it takes longer to tune that just turning the knob on an MBC. IMO it's worth it though.
Adi489
22
Aug 14, 2013 02:18 AM
deadstockkpomp
11
Jun 29, 2012 06:33 PM
MarineEric
Southeast Region
Feb 11, 2011 10:37 PM
smp3000
33
Oct 21, 2009 11:53 PM
Dapper Dan
Mar 16, 2008 08:45 PM
