Over Boost problem
Old Feb 11, 2011 | 10:01 PM
MarineEric's Avatar
Over Boost problem
So i have a bit of an over boost problem. What im wondering is could a bad throttle body shaft seal be the cause? I talked to a buddy of mine and that was one of the conclusions he came too. Its also got an irregular idle.
Old Feb 11, 2011 | 10:11 PM
evo8426's Avatar
the throttle body shaft seals would cause the car to not hold boost.
what do you mean irregular idle? do you have aftermarket camshafts installed? that could be the culprit of the idle problem
also, what do you mean over boost? like is the car hitting fuel cut or is the car hitting several psi higher than set to? if so then turn the boost down with your manual boost controller if youre using one
what mods are on the car?
Old Feb 11, 2011 | 10:37 PM
MarineEric's Avatar
irregular like it wont go out of warm up phase, sometimes it does but when the rpms settle off to normal, it fluctuates weird. yeah i have cams but its never really acted like this. its like the car hits a wall when im getting full boost. what would cause a fuel cut like that?
babaz7
10
Jun 21, 2017 08:00 AM
Ichimaru
Jun 24, 2010 02:48 AM
wickedwhiteIX
10
Mar 30, 2009 06:19 PM
Evolved Monkey
Mar 29, 2006 02:43 PM
RealVibes.net
Nov 12, 2004 02:22 PM
