05 evo 8 wastegate not working properly, will evo 9 WG fit?
Old Nov 7, 2011 | 10:03 PM
TigOLDBiTTies's Avatar
my car is lagging alot and ive tried taking it off and adjusting it. i think its leaking or just not working properly, and all the Wg's that i see for sale are for evo 9 turbo's. what do you all suggest i do? im going to upgrade to an evo 9 or a green in the future so i dont want to spend that much on a WG.
Old Nov 8, 2011 | 10:59 AM
and some additional info, i have an 04 and my turbo went out so i bought a replacement from a guy on here who sold me an 05 evo 8 turbo with 10.5 hotside. i re used my old WG off of my stocker with 9.8 hotside and i have been having issues since. would the 10.5 hotside make the old wastegate not work? and since the 10.5 hotside works on evo 9 turbo's would i have to purchase a evo 9 WG or an evo 8 WG?
Old Nov 8, 2011 | 11:08 AM
nocabiwiksmx's Avatar
evo 9 wastegate actuator will not fit because it bolts to the compressor housing on the 9 which is bigger
i went from a 9.8 hotside to a 10.5 hotside and resused the 9.8 wastegate actualtor and it was fine. hook the actuator line up to a bike pump and see if it moves when you put some air pressure in.
Old Nov 8, 2011 | 12:59 PM
AWDBus's Avatar
Did you preload it when you put it on? When I did my swap I had to readjust the wastegate as the length was off from the 10.5 hotside. There is a few vids floating around that helped me when I had to redo mine.
Old Nov 8, 2011 | 02:11 PM
yes, i loosened the waste gate arm so that it slipped on and off on the flapper arm. then i turned it 3 full revolutions tighter and pulled it over the flapper arm. thats what everyone else said to do. it feels laggy and sometimes it will build boost and it feels very torquey then all of the sudden it spools up and all that Tq falls off fast. i cant go full throttle right now because its not tuned yett and its running really rich. ive done boost leaks tests and changed the throttle seals, removed EGR, sealed all my intercooler pipes with high temp rtv... i think its either then wastegate leaking or the turbo going out.
Old Nov 8, 2011 | 02:28 PM
sparky's Avatar
My experience is that a WGA for an VIII turbo won't work on a IX turbo. However, I have never tried a IX WGA on an VIII turbo. My guess is that it ain't gonna work for you.
Incidentally, how are you controlling boost(MBC, EBC, etc.)?
Old Nov 8, 2011 | 04:12 PM
AWDBus's Avatar
If you use the 8 cold side, then you use the 8 wga. Same for the 9 cold side, it uses the 9 wga. Hot side didnt matter, at least for me when I swapped from 9.8 HS to a 10.5 hotside on the 8. When I put the 9 on, it took the 9s wga.
When I readjusted mine, I pulled the o2 housing back off so I could make sure the flapper was sealing. I had some weird issue with it that was not allowing it to close (something I did wrong, but cannot remember what it was).
Try like somebody posted above, a vac. pump on the wga. I think I have a 8 wga if you need one. Just pm me and pay shipping.
Old Nov 8, 2011 | 06:26 PM
im using a hallman pro MBC, but i have a GM 3 port sitting in my drawer waiting to go on. im just waiting to get it tuned first, and i dont want to waste my money tuning it with a leaky WG.
and thanks AWDBUS, ill let u know if i need the WGA.
Old Nov 8, 2011 | 06:34 PM
Anubis18's Avatar
I personally don't think your wastegate isn't the problem. It sounds to me like a vacuum leak or a boost leak. I would check all your hoses, lines and piping
DSMolition
Nov 10, 2016 10:35 AM
nor11384
Aug 2, 2015 09:39 PM
evodziobak
11
Nov 11, 2013 09:07 AM
Synapse
18
May 2, 2010 05:05 AM
