test drive went wrong..
Old Nov 9, 2011 | 12:33 PM
OfaceGrimmins's Avatar
Originally Posted by EvoVIIIxoxo
pics...
Oh, ouch dude. Sorry to see it.
Old Nov 9, 2011 | 05:30 PM
Blitz's Avatar
also, would anyone happen to know a place in the states that i could send my tc to be repaired? if so let me know thanks..i will be removing it myself to save labor costs.
http://www.sheptrans.com/transcase/evo.htm
http://teamrip.com/EVO_TRANSFER_CASE_SERVICES.html
Old Nov 9, 2011 | 05:46 PM
Zerokei_XF's Avatar
I recommend shep trans... You can't go wrong with their stuff/ I've seen people have their trannys or xfer cases rebuilt by them then beat them to death in high horse power cars and they still shift like a hot knife through butter.
Old Nov 9, 2011 | 06:08 PM
mekis13's Avatar
That sucks man..... When I did my clutch I changed all my fluids and I was scared I didn't fill them enough or remember to. Sucks to see this happen after sitting for a build.
Old Nov 9, 2011 | 07:59 PM
06RedRalli's Avatar
Jack's transmission.
Old Nov 10, 2011 | 10:09 AM
dotman05's Avatar
thats no good..sorry to hear
Old Nov 10, 2011 | 11:13 AM
surferjeff's Avatar
That used to be a ring and pinion
Old Nov 10, 2011 | 11:21 AM
ILoveAWD's Avatar
Originally Posted by evosdad
Sounds horrible. Pull t case and try that first, spin the shafts if it's ok, move on to trans.
Do this second
Originally Posted by jdm phil
could be clutch
Wouldn't be the clutch, if the clutch was broken and stuck in a gear I would still be able to roll
Originally Posted by barneyb
I'd pull the fill plugs on all three gearboxes and check the oil levels. The level in each should be up to the opening or close. If a gearbox is dry you have found the problem.
and do this first
Old Nov 10, 2011 | 11:46 AM
RevRevGone's Avatar
I had this issue after mitsu replaced my first t-case. I drove the car for 74 miles and BAM, the car went nuts. I got it to roll to the top of the off ramp and then it locked up. Put it in reverse and it rolled like 2 inches. Put it in 1st and nothing would not move at all. Called mitsu, they took it in and looked at it. They said it is your t-case, we left out an upper o-ring.
So I am going to say it is your t-case!
Old Nov 10, 2011 | 11:58 AM
05blue8's Avatar
Did you buy it like that? Did a shop service it and not refill it? How did it end up getting dry in the first place?
Old Nov 10, 2011 | 12:10 PM
gone2pimp's Avatar
It look like th OP forgot to refill his transfer case after a motor build
Old Nov 10, 2011 | 12:41 PM
Ev0ikon's Avatar
You may as well get a new transfer case. And don't forget the o-ring between it and the transmission.
Old Nov 10, 2011 | 12:57 PM
Pal215's Avatar
Oil, oil, oil. Such a simple liquid that if left forgotten costs us thousands. Send it to shep trans for a rebuild and get it back even stronger than it was before.
Old Nov 11, 2011 | 03:10 AM
MR. EVO MR's Avatar
****ing sucks when you don't realize all the steps in reverse. At least now make sure the new one is a built one for future powa upgrades. GL.
Old Nov 11, 2011 | 03:15 AM
Revo15's Avatar
Tcase went kabloom!
