fp 25# wastegate no boost
Old Nov 18, 2011 | 01:11 AM
evoiao's Avatar
ok so I installed a fp 25# wg and now no boost? afr is 14.7 and at idle -16 to -18 vac. Boost comes in when I'm in 3rd gear, maybe around 3 to 4 # of boost.
Did I install the wastegate in correctly?
please advise.....thanks
car runs normal in all other respects, just no turbo.....prior to the wg install everything was fine.
Old Nov 18, 2011 | 01:18 AM
evoiao's Avatar
ttt help
Old Nov 18, 2011 | 01:21 AM
Blue91lx's Avatar
Chill....You don't need to bump your thread after seven minutes.
Old Nov 18, 2011 | 07:36 AM
cfdfireman1's Avatar
Don't know
Did you?
http://store.forcedperformance.net/m...gh-setting.mpg
Old Nov 18, 2011 | 07:50 AM
TheBoz's Avatar
it also sounds like you might have some IC piping that is coming appart. Go double check all the IC piping on the car while you check the WGA.
Old Nov 18, 2011 | 08:02 AM
siceclipse's Avatar
im gonna say its not adjusted tight
Old Nov 18, 2011 | 08:58 AM
evoiao's Avatar
your advise - not very helpful
if your going to respond most members are either helpful or butt heads! Now you get to choose which one you'll be
Old Nov 18, 2011 | 08:59 AM
evoiao's Avatar
thanks
Originally Posted by cfdfireman1
thanks you this did work.
Old Nov 18, 2011 | 09:01 AM
GGevo921's Avatar
1/8 of an inch tighter from how it comes. it will be a stretch to get on ull have to pull on the flapper a little to get it to slide on. Then Test it. Push air through it till it opens and see if the psi causing it to open it is 25psi or less or more and adjust till 25psi opens the wastegate. HTH!
Old Nov 18, 2011 | 11:05 AM
sparky's Avatar
What is your target boost level?It is weird that it is only reaching 3-4 PSI. If properly installed there is no way it should only get to 4 PSI, as long as the actuator is in perfect working order. Something is wrong.
Old Nov 18, 2011 | 11:24 AM
Blue91lx's Avatar
Apparently they also respond to things that do not at all require a response.
Old Nov 19, 2011 | 08:33 AM
evoiao's Avatar
some people
that's very witty how long did you sit at the computer to think that up, your so cleaver, I just kenw you'd go the butt head route.....try just helping, I see your new as well if you don't know the answer it's ok. You can still stick around and make useless comments to make yourself feel smarter....I guess?
Me I'll ask all the stupid question I want and need to to make sure I get my car running properly.
Old Nov 19, 2011 | 08:36 AM
evoiao's Avatar
thanks this was very helpful! and it did work.
Old Nov 19, 2011 | 06:51 PM
Blue91lx's Avatar
I sat here for hours upon hours, actually. I apprecite you making this thread, as it has provided an opportunity for me to place useless comments like this, which is indeed conducive to my self-esteem. Useless comments wouldn't be so fun without your responses, so keep them coming!
Old Nov 19, 2011 | 06:56 PM
GGevo921's Avatar
Anytime! Im glad i could help out. I bet 25psi feels a lot better than 4. lol.
