fp 25# wastegate no boost
Old Nov 19, 2011 | 09:40 PM
evoiao's Avatar
Originally Posted by GGevo921
Anytime! Im glad i could help out. I bet 25psi feels a lot better than 4. lol.
it just feels good knowing i didnt fubar my car......and it's not getting 25# it spikes too 23.6/23.7 I did have a rreflash a year ago, I getting ready to put 1200cc injectors and switch to E85, I have all the bolt on mods, and upgraded the cams to kelford 270 along with supertech dule beehive springs and retainers, so next week injectors, mustang dyno tune to e85...what awhp do you think I should put down.....??????
Old Nov 20, 2011 | 08:15 AM
cfdfireman1's Avatar
how many fuel pumps do you have? careful boosting more than what you were tuned for.
Old Nov 20, 2011 | 09:18 AM
sparky's Avatar
This just goes to show that you can't just slap on an FP 25PSI actuator, or any actuator for that matter and assume that you'll be seeing 25 PSI base pressure, or whatever the actuator's advertised pressure may happen to be. Although, I am still surprised at the OP's extremely low reading as 3-4 PSI seems way low. It may be that the actuator rod on the OP's unit is a bit too long to start with. Or he may be experiencing other issues such as a boost leak or a weak diverter valve spring. It's just that it is generally held that base wastegate pressure even with the stock actuator is 7-8 PSI.
Old Nov 20, 2011 | 10:03 AM
evoiao's Avatar
I think it was the wga rod, it was to short, I was not sure where the pivot arm should be positioned. once pointed in the right direction, the boost returned.
Im currently flashed for 21 or 22 I dont remember....since the flash Ive had the cams installed and now that sema is over the tuner can re-tune the car and replace the injectors to e85.......the diverter valve is the metal mitsu one bought it new from the lancer shop....I do have a fourge one but didn't like the flutter and hopping it caused.....I'm kind of entertaining the idea of a tial or synapse Synchronic DV???
Old Nov 20, 2011 | 10:05 AM
evoiao's Avatar
Just the one walbro 255.. what do you think? ive been told its enough for now?
Old Nov 20, 2011 | 10:22 AM
GGevo921's Avatar
What turbo are you running? if your running a stock turbo and have upgraded injectors as well you should be fine as that shouldnt run out untill about 450whp on a mustang dyno, then you'll need a larger fuel pump.
What fuel do you dd on?
Old Nov 20, 2011 | 12:22 PM
evoiao's Avatar
currently california's best 91 octane, but next week in go the injectors and a retune to e85......maybe a dbl pumper is in santas wish list....then if all things go well it's be time for a new stock frame turbo in feb of next yr. then tires/wheels then a voltex wide body....... but for now e85.....all possible bolt on mods are done and cam are in so....now it get expensive.....heheheheh
Old Nov 20, 2011 | 12:52 PM
evoiao's Avatar
hi sparky
you had some really good ideas, whats your thought on changing the dv to a tial or synapse dv??? or stay with what ive got???
Old Nov 20, 2011 | 03:47 PM
sparky's Avatar
I think it was the wga rod, it was to short, I was not sure where the pivot arm should be positioned. once pointed in the right direction, the boost returned. ....
I am glad that you resolved the issue!
Old Nov 20, 2011 | 03:59 PM
sparky's Avatar
I think that a single, healthy, modded WALBRO will suffice for fuel supply even once you switch over to E85 fuel as long as you are still on the stock turbo. Of course, you'll have to punch it. Punching it shuts a pressure relief valve in the pump. Or alternately, you might want to increase the voltage to the pump by either: 1)"hot-wiring" it or, 2) adding a Kenne-Bell Boost-A-Pump. either one of these three methods will increase the output of your Wally.
At least I think that you should be OK with the Wally modded as by one of the three methods outlined above. I am pretty sure that a lot of peeps on here that are running E85 on the stock turbo are doing it with a modded Wally. Do some searching on the subject, though.
Old Nov 20, 2011 | 04:23 PM
sparky's Avatar
.......the diverter valve is the metal mitsu one bought it new from the lancer shop....I do have a forge one but didn't like the flutter and hopping it caused.....I'm kind of entertaining the idea of a tial or synapse Synchronic DV???
Me I would just keep the metal IX DV and crush it. If you are interested, send me a PM and I'll tell you how to go about crushing it. At least, I think that you'll be fine with a crushed stock one at the boost levels that you are currently running. Even once you switch over to E85 you won't be running any higher than 28-30 PSI, will you? If it ain't broke don't fix it.
Old Nov 26, 2011 | 11:24 PM
evoiao's Avatar
it's now boosting 24.7 to 26.3 woohoo
Old Nov 27, 2011 | 08:35 AM
GGevo921's Avatar
single walbro is good to 450whp on mustang dyno
Silver-IXse
May 16, 2013 08:40 AM
Scott53092
14
Jun 4, 2012 09:32 AM
Mauricio Evo IV
12
Jun 13, 2011 06:18 AM
kouzman
Apr 3, 2008 04:35 PM
