Small Coolant Leak
Old Nov 24, 2011 | 12:06 PM
KJS's Avatar
KJS
Small Coolant Leak
So I was pulling out of my drive way today and noticed a small puddle had formed. So I stopped the car and check and it seems that I have a small coolant leak on the passenger side about wheel deep. It only happens when the car is idleing. Can anyone give me some guidance here? I was thinking it might be the water pump?
No thick white smoke coming out of the exhaust.
Old Nov 24, 2011 | 12:10 PM
4RETECH's Avatar
Yeah, most likely your waterpump.
Look at the weep hole. Might be from there.
Old Nov 24, 2011 | 12:32 PM
KJS's Avatar
KJS
What does that look like and what can I do if it's the weep hole?
The car is at 37k, would it be smart to just do the timing belt and the water pump if that's the cause just because you have to take everything off to get to the water pump?
Also how quickly should I be worried about fixing this? I have a tub of coolant in my trunk to keep filling the escaping coolant, so could it wait a couple of weeks?
Old Nov 24, 2011 | 12:34 PM
awdturbo8's Avatar
I have the same issue. Mine is leaking down the side of the block on the passenger side. I can't figure it out. It keeps getting worse.
Old Nov 24, 2011 | 12:39 PM
KJS's Avatar
KJS
Downside the block... might be a blown gasket?
Mine isn't down the block is leaking from the bottom of something about wheel deep... I'll get the car on jacks Sunday and see If I can get some pictures
Old Nov 24, 2011 | 12:44 PM
awdturbo8's Avatar
Blown head gasket?
Old Nov 24, 2011 | 01:26 PM
KJS's Avatar
KJS
I dont really think I blew my head gasket because there is no white smoke coming out of my engine and nothing out of the ordinary happened...
How long does coolant take to get into the oil system?
Still looking for answers for some of the questions above.
Thanks in advanced.
Old Nov 24, 2011 | 02:04 PM
4RETECH's Avatar
http://www.flickr.com/photos/57648191@N03/6232379753/http://www.flickr.com/photos/57648191@N03/6232379753/ by http://www.flickr.com/people/57648191@N03/, on Flickr
Maybe you can see this one in the picture.
Sorry, doing thanksgiving. LOL
Old Nov 24, 2011 | 06:24 PM
KJS's Avatar
KJS
Yeah I figured it would be slow on evom because of the holiday, anymore input would be appreicated
Old Nov 24, 2011 | 08:18 PM
awdturbo8's Avatar
I was actually referring to your reply. ^^^ what gasket are you talking about that I might have blown?
Old Nov 24, 2011 | 08:47 PM
bigben's Avatar
I had an aftermarket waterpump that's had a very slow leak for the past 2 years. Well, it's leaks down to a certain point, and then stops.
Old Nov 24, 2011 | 09:11 PM
KJS's Avatar
KJS
Head Gasket. Search on here for a thousand threads of symptoms
There is no coolant on my block or near it. My leak is from the bottom of something on the bottom of the engine bay. I finally got some time to take a closer look, but it was dark, it might actually be a hose.
Ill get some pictures up in the next few days for some more clarification.
Old Nov 26, 2011 | 10:22 PM
jdmstud's Avatar
check all hoses first before thinking the worst
Old Nov 27, 2011 | 08:38 AM
mithrandir7533's Avatar
You don't have to have white smoke for a blown head gasket.
timv
16
Jun 6, 2021 03:11 PM
changocox1322
Feb 24, 2016 07:09 PM
mrm95
Dec 13, 2013 04:45 PM
mx4life85
Oct 3, 2013 03:13 PM
thedru13
10
Nov 1, 2011 05:40 PM
