tighten E brake?
Old Nov 21, 2011 | 06:46 AM
88888's Avatar
tighten E brake?
my e brake doesnt feel as solid as it used to any more. i really need to pull on it to get that braking power. is there a way to make the cable tighter?
or is there a ebrake brake pad?
Old Nov 21, 2011 | 07:01 AM
05blue8's Avatar
It isn't an e-brake, it's really a parking brake. Yes you can pull up the center console and tighten the cable some but the ideal way is to pull the rear calipers and adjust it there. It's just a drum brake that locks on the inside of the caliper. If you have the time loosen the cable up and adjust the drum shoes. If not then just use the cable locking nut under the center console.
Old Nov 21, 2011 | 09:07 AM
88888's Avatar
thanks for the correction
i will be tightening the center console bolt for now. but i have gone inside the caliper as well with not exactly knowing what to tighten. are there any pictures or links for what needs to be tightened once the caliper is off?
Old Nov 21, 2011 | 09:43 AM
tsidrift1's Avatar
I would say its easier to adjust it the correct way. Jack the rear up, pull the wheels off. There is a hole you can get a screwdriver in. I believe you dont have to even take the rotor off? I cant remember for sure. But just spin the small gear till you ebrake handle gets tighter again. Easy.
zeero260
May 20, 2025 05:50 AM
BrunoBoy650
Dec 28, 2013 04:59 PM
R/TErnie
Feb 10, 2013 06:26 PM
j14mp
15
Jul 10, 2009 11:36 PM
evo8 951
Jan 2, 2008 08:56 PM
