Beatrush Underpanel
Beatrush Underpanel
Ok clowns! FYI, I really don't know where to place this thread so I'll leave the mods to transfer what section it needs to be in.
If you have a SE lip for your EVO IX don't be surprised that the Beatrush under panel will have some space between the panel and the lip.
The Beatrush under panel is designed for regular OEM lip NOT for SE lip. It still works and does its job but you will have some space. I had a zip tie to hold the front of the panel because the plate where you bolt the panel do not reach.
Here are some pics so you will have an idea on what I'm talking about.
Cheers{thumb up}
By the way, look what showed up on the mail
Haters and hypocrites, back off.
Cheers{thumb up}
You are missing the three SE extension pieces.
Look here and talk to Russell: https://www.evolutionm.net/forums/mi...63-se-lip.html
^ Why do you say that?
My OEM SE lip was the same way. 3 extension pieces are needed.
I ran beatrush undertray with regular lip and then went to SE. Those gaps look normal until you the 3 pieces are added on.
the point is that's not even an OEM lip, regardless of if it has the extensions or not.
one the OEM lip all of the bottom mounting holes (that mount to the undertray) are extended out from the lip
that's what the OEM lip looks like in terms of mounting holes (with the extensions)
J!n K@z@mA
For Sale - Wheels / Tires / Suspension / Brakes
Mar 31, 2012 11:14 AM
