backfire when WOT
Old Nov 23, 2011 | 08:29 PM
HN7's Avatar
HN7
backfire when WOT
My car has been backfiring under WOT lately since the weather dipping into ~40 C. When I step on it and the rev goes pass 5k RPM, I can hear "bap,bap,bap" coming out of the exhaust, sometimes a loud pop coming from the engine and I lose power temporary.
The car was pro tuned this summer in 80 degree weather. Do you guys thinks I just need a retune? or is it something more serious?
EDIT: My car just has the basic bolt-ons: full BR exhaust (straight pipe all the way), BR IC and pipes, Walbro. My CEL is on because I still need to put a O2 spacer on the rear 02 sensor
Old Nov 23, 2011 | 08:36 PM
kanyonkid's Avatar
change ur plugs sir..
Old Nov 23, 2011 | 08:37 PM
HN7's Avatar
HN7
^Will try that tomorrow. Thanks.
Old Nov 23, 2011 | 11:27 PM
Andrewkbmx's Avatar
plugs are a good start, but with it being cold its probably over boosting. keep an eye on the gauge once when you do it. Mbc? i know my evo on a stock solenoid in the wisconsin cold would hit 30 no problem. even with a mbc it will creep up in the cold probably have to turn it down a tad
Old Nov 23, 2011 | 11:38 PM
blkmkIII's Avatar
Who tuned the car?
Old Nov 24, 2011 | 08:59 AM
HN7's Avatar
HN7
Originally Posted by blkmkIII
Who tuned the car?
Kasey @ HIS Motorsports in NC.
Old Nov 24, 2011 | 02:42 PM
ReaperX's Avatar
More than likely it's your plugs like said above. With the colder temps my car was over boosting slightly and would pop a few times at full boost. Pulled the old set of plugs, there were a little fouled, dropped in some non protruding plugs and no more issues. Gap on the old plugs opened a bit and I have a slight boost leak so that didn't help either.
If plugs don't do it test for a boost leak.
Old Nov 28, 2011 | 11:36 AM
HN7's Avatar
HN7
It was the plugs. Thanks for the help.
Old Nov 30, 2011 | 10:17 AM
CodyEvo's Avatar
Yeah haha friend had same problem and plugs helped aswell
akira2_03
21
Dec 5, 2016 01:46 PM
itsmeek
Aug 24, 2015 03:01 AM
scheides
May 28, 2015 12:01 PM
evox_dev
May 24, 2015 07:36 AM
anton406
Oct 28, 2007 10:16 AM
