bogging and backfire at wot 2k rpm
Old Oct 25, 2014 | 05:35 PM
evox_dev's Avatar
hi i have a 2008 evo gsr im currently in the process of tuning my car and im doing wot pulls from 2-7k and my car is bogging and backfiring wot . been searching for a week cant seem to find a solution
ams downpipe
custom exhaust
k&n intake
1000 cc injectors
3.5 innercooler piping
stage 3 clutch
Old Oct 27, 2014 | 10:38 PM
franzcars's Avatar
Do you have a AFR guage? Could either be not going into open loop soon enough, could need new plugs
Old Oct 28, 2014 | 01:52 PM
evox_dev's Avatar
i have a afr gauge it goes lean as soon as i got 50% on throttle .. i changed plugs gapped at .20 , it does it in all gears soo now im changing fuel pump
Old Oct 28, 2014 | 03:06 PM
franzcars's Avatar
It's either the relay or the open loop load High Octane map is set too high so that its still closed loop. I'd start with the relay and see if that fixes it, if not it's part of the tune
Old Oct 29, 2014 | 09:29 PM
evox_dev's Avatar
i had the green relays in about to the newest black omron one and i switched the green ones back out and it still does it so i put the new black ones in .. i changes spark plugs and im thinking new coils and fuel pump ..
Old May 24, 2015 | 07:36 AM
LogicGate's Avatar
Was the source of this issue identified and resolved? I am having the same issue.
4G63_Crazy
22
Dec 3, 2017 02:47 PM
Igaly1021
Nov 7, 2015 05:18 PM
evox_dev
Oct 25, 2014 04:54 PM
OfaceGrimmins
30
Nov 15, 2011 02:11 PM
MercenaryX2
Feb 1, 2011 05:43 PM
