help car is having hiccups/bogging
Old Nov 27, 2011 | 03:16 AM
maevo8's Avatar
Same thing happen to me right after my tune replaced my plugs and that fixed te problem ..
Old Nov 27, 2011 | 07:03 AM
fabcas311's Avatar
thanks guys... i will be replacing the plugs today.... but my tuner also mentioned the fuel pump housing????... i have the walbro 400lph..... what do i need to check regarding the housing??
Old Nov 27, 2011 | 07:17 AM
Fastone_evo6's Avatar
please start whit the plugs , and write here and tell of its gets better.
Old Nov 27, 2011 | 07:30 AM
fabcas311's Avatar
will do
thanks
Old Nov 27, 2011 | 07:48 AM
ABNEVO's Avatar
I had the same jerky feeling after a brand new NGK plugs installed and tuned. They re-gap the plug I believed it was .20 and everything was back to normal. Good luck though
Old Nov 27, 2011 | 05:32 PM
fabcas311's Avatar
update: changed the plugs but same thing happened.
so i decided to check the fuel pump and there the fuel pump came off from the housing.
the guy who installed my walbro 400 lph cut the bottom part of the housing and the only part was holding the pump was the hose, so the pump was literally floAting inside the gas tank!lol... so i placed the pump back into the housing, drove the car and damn! its a beast again!!!!!
thanks guys!
Old Nov 28, 2011 | 04:46 AM
good work mate . you u dont hire the guy to make any more install on your car
Old Nov 28, 2011 | 05:26 AM
rhd-jon's Avatar
Nice to hear that. Sometimes it can be the smallest
things that's why evoM is here to help other members out.
Old Nov 28, 2011 | 06:27 AM
smoothy's Avatar
Awesome...nice to know. Hopefully I never have this same problem, but good to know anyways
Old Nov 28, 2011 | 07:14 AM
yellowcr's Avatar
my car does this same thing sometimes. and i have a similar setup guess i gotta look into this
Old Nov 28, 2011 | 08:40 AM
ILoveAWD's Avatar
same thing happened to me, mine was an easy fix though. what had happened was my connector for my throttle position sensor and disconnected. the car drove normal until i went under boost then it would just bog down and back fire. check that and let us know what it really is when you find out!
ILoveAWD's Avatar
thanks guys!
sorry didnt read the whole thread at first just saw that you fixed it good work bro!
4G63_EVO
Jun 8, 2017 10:02 PM
David Buschur
114
Feb 4, 2013 09:02 AM
Viet-Speed
May 19, 2012 12:58 AM
EVOB23
Mar 20, 2012 06:42 AM
David Buschur
86
Oct 21, 2010 06:36 AM
