hks 280 cam gear setting ?
Old Nov 28, 2011 | 08:25 AM
svt_lightning01's Avatar
Okay so this may be a stupid post but my car doesn't want to lope except just every once in a blue moon it will hit a lick for a second. I think this is weird considering it is a decent cam? The cam gears are set to -4/-1. Could the setting keep it from loping? I know power is great but i love a good lope and its driving me crazy! It idles between 850-950 most of the time. I mean i see alot of people just have them at 0/0 or like -2/-2? Just curious i was told this -4/-1 is for top end. Reguardless could changing it affect lope? Thanks.
Old Nov 28, 2011 | 10:13 AM
Anyone?
Old Nov 28, 2011 | 01:58 PM
Fastone_evo6's Avatar
try setting the cam gear 0-0 , your tuner shuld help you dileing in the cam gears , depinding on the powerband you whant , need to do this on a dyno , to make the best result , takes a hole day
Old Nov 28, 2011 | 02:06 PM
the car made some good power they way that they are. I was just curious if the settings affected cam lope or not? I know it idles low enough to do so.
Old Nov 28, 2011 | 02:08 PM
evo 9 guy's Avatar
IIRC, John Bradley just posted some info on this in the ECUFlash forum.
Edit - Take a look at the info in this thread. Good stuff...
https://www.evolutionm.net/forums/ec...ce-timing.html
Old Nov 28, 2011 | 02:21 PM
meckert's Avatar
The setting you are using are for top end perf as you indicated and yes those settings will give a tamer idle as a result. Moving them ie advancing the timing will add "lope". I have to say, performace minded folks, no matter their preference --top end or low end, build for that reason.. Making changes cause it sounds good???? I will never understand. But GL.
Old Nov 28, 2011 | 02:22 PM
thanks man that is some good info i posted up there also to get their input
Old Nov 28, 2011 | 02:23 PM
so basically if it go to a say, -2/-1 setting it will lope more but i will lose power? I thought the settings only shifted the power band between low and high rpm?
Old Nov 28, 2011 | 02:25 PM
no no i wont trade performance for sound by any means but i wasn't aware that changing it lost power i thought advancing the current settings would only bring more mid range and pull power from top end?
Old Nov 28, 2011 | 02:32 PM
meckert's Avatar
You dont lose power, the power band curve moves to the left or in you case will add more midrange at the cost of topend power. I am running 274/278 HKS cams, at +2, -1 and its fine in idle sound and quality.., ran 272\264 earlier and same thing with the same settings---now this was for better lowend and midrange---thats what this kind of change will net you... to add power in places it has to come from somewhere else. A tighter lobe center will make it idle lopey and thats what these settings will get you... run 0/0 first and see what you think.
Old Nov 28, 2011 | 02:48 PM
pm'd you
Old Nov 28, 2011 | 03:06 PM
okay well its sounds like -2/-1 would shift back some towards midrange and lope more and 0/0 would do so as well. Retune required or not?
Old Nov 28, 2011 | 03:14 PM
meckert's Avatar
Thinking so, last time I made cam ajustments just like this-- I picked up knock in upper rpms around 6-7k. Not to say you will and others may say no need. Just telling you what i picked up. Disconnect your battery as well, that will reset the ecu and get you real close.
Old Nov 28, 2011 | 03:18 PM
okay awesome. And you are at +2/-1 and your idle is lopey? you prefer lopey idle also ? lol
Old Nov 28, 2011 | 03:41 PM
meckert's Avatar
I like a good idle, somewhere between lopey and stock --a solid rumble.--but as I said earlier, I really perfer lowend/midrange power over topend power and as a by product I get the rumble, but not thumping. I drive on the street, don't do any 1/4ml stuff, we have an 1/8 mile track close by-- but I like road racing and instant power on when I pass, just flick the throttle and its done. I dont like a lot of attention-- so I tend to pass on loud exhaust, lopey idles, and anything else that says---GIVE ME A TICKET PLS! old school sleeper.
