Cant hit full boost and car starts chugging at higher RPMs?
Im having the same problem on my 05 MR... No cels.. Stock evo9 dv valve.. ETS intake.. BPR8ES plugs.. is tuned by Sean Ivey.. Ran awesome then one day just would boost to 15lbs and thats it and starts to break up real bad.. I made a boost leak tester yesterday Im gonna do a leak test this sat.. Hopefully its just a boost leak but Im thinkin its somethin else..
Do a proper boost leak test, also check your t/b seals. It's grossly underestimated what a boost leak can fix. Cam sensor too
Boost leak
T/b Seals
Cam Sensor
Wga
Id do that order for starters
Boost leak
T/b Seals
Cam Sensor
Wga
Cam Sensor would probably need to be resistance tested, or voltage tested depending on its signal.
WGA , you need a hand pressure pump, apply 17in/hg of pressure and the rod should move. we just put a air sprayer tip on our air compressor and just open the valve a tiny bit to leak out 17psi and make sure it moves. kinda the easy cheaper way then a hand pressure/vac pump.
Do the cheap things first. Check plugs and gap mine at .022 and do a professional boost leak test. A couple of months ago my 2003 VIII evo had the same problem was boost leak couldn't find it/see it or hear it myself. Runs great now once I got it fixed.
I figured out my issue, in case anyone has simillar problems, felt like either a boost leak or bad plugs. it turned out that I pulled the fuel pump, and the gromet that sits on the stem on tp of the pump like a cap had slid down and excess fuel was just being sprayed out the sidees i guess and back into the tank. That OEM gromet probably got worn from age and me pulling it out once before just did it in. the replacement cost i think 2.00 on stm's site. Hopefully this gives a little help to anyone feeling the same thing!
Thanks again for all the suggestions!
SpeedI2acerX
18
May 20, 2017 10:50 PM
BoostedDaily
15
Sep 29, 2014 02:40 PM
