AMS has discontinued cnc ported head
Old Dec 7, 2011 | 11:10 AM
project_skyline's Avatar
Cool database on head flow for lots of different heads.
http://users.erols.com/srweiss/tablehdc.htm#MITSUBISHI
Old Dec 7, 2011 | 11:20 AM
blackgsx01's Avatar
Originally Posted by project_skyline
Force fed performance CNC head is as baller as it gets.
+1
I am running there cnc head. Good people to work with. Awsome product! Cant wait to get back and have justin and bobby working/tuning my car.
Old Dec 7, 2011 | 11:33 AM
JohnBradley's Avatar
Number 1 and 4 on the outside edges of the exhaust port have the issue in some heads. It is always in the same place though so identifying it can be done prior to install but has to be done after the port.
Aaron
Old Dec 7, 2011 | 11:50 AM
laramie_05MR's Avatar
Originally Posted by Kracka
MAP does beautiful port work too, a bunch of my friends have their heads (VIII, IX, and X).
My stg. 5 is very nice.
Old Dec 7, 2011 | 04:34 PM
KTM_EVO's Avatar
Theres a guy in the forms selling a AMS CNC ported head!!! it was there yesterday
Old Dec 7, 2011 | 05:03 PM
brp's Avatar
brp
yup that guy would be me, check the link in my signature and PM me for any info if interested. It is an evo 9 head though so might not work for the OP. Thanks for posting this KTM
Old Dec 7, 2011 | 05:18 PM
The GSC CNC head is still available exactly as I run on my car and the White Evo.
Old Dec 8, 2011 | 05:22 AM
AngryEvo8's Avatar
Originally Posted by evotuner04
why are they doing this?
Because they have set so many records allready and have moved on to bigger and more expensive platforms.
Old Dec 8, 2011 | 06:19 AM
Andrew@AMS's Avatar
We do still produce parts and work on the Evo 8/9/X platforms. Also we will revisit this once a solid solution has been found for this issue but at this time we have decided to put it on hold.
We have started to work on other platforms but we have not stopped working on the Evo 8/9/X
Old Dec 8, 2011 | 07:11 AM
WHTEVO's Avatar
To AMS, so if the car has already used your head, and no coolant was dumping into the combustion chamber, the head is fine? I just want to clarify since i personally have bought one from you guys.
Aaron
Old Dec 8, 2011 | 07:20 AM
Andrew@AMS's Avatar
Aaron
That is correct, if you currently have one on your car and the car is running fine with no coolant burning issues then you are ok. If there was an issue then it would have leaked coolant from the first start of the engine after the head install.
Old Dec 8, 2011 | 09:21 AM
1d10t's Avatar
AMS is still a top notch place guys. I just wanted to inform the forum.
Stock evos are rare, but they wouldn't stop doing this service without a real cause.
I mean, its a cnc program lol.
Can't blame shops for expanding their horizons either, as the limits of the ct9a are pretty much met.
Old Dec 8, 2011 | 09:39 AM
Jrod@Buschur's Avatar
Originally Posted by Tsurugi-san
Buschur or Cosworth, depending on your preference (and budget).
Thank you for your recommendation. We appreciate your support.
Our products are track tested & reliability proven time and time again. They speak for themselves. We do a LOT of heads and blocks as well as still offer all of our other power producing products and supporting mods. We will be glad to help any of you any way we can. Feel free to inquire with us about whatever you may need or would like pricing on.
Take care!
Old Jan 5, 2012 | 10:05 AM
Force-Fed Performance's Avatar
Thank you for the comments on our heads also project and Ross. We have also seen this casting problem in the mitsu heads and it does hurt the CNC process. Fortunatly we have a solution for the problem and have not had a problem with any of our heads since fixing the issue and still flowing like a mad man with STD size valves.
Old Jan 5, 2012 | 06:43 PM
boostless's Avatar
I would have to disagree with this comment as shops are still successfully developing for the Honda B series engine...and that engine is older than some of its drivers
