Forge rs bov adjustable?
Old Dec 7, 2011 | 11:42 AM
svt_lightning01's Avatar
Im on 30psi and wonder how i know that it is "adjusted" correctly? I have read up some on the topic and it is currently about 8 or 9 turns from all the way to the (-) end. I didn't know if you could over adjust it? Right now it is making 30 psi peak and tapering to about 24-25 and when i first had it it was about 2 turns and it tapered to like 22-23 so i know the turns helped. But i have slight boost surge in high gears but nothing drastic.
Old Dec 7, 2011 | 12:46 PM
jvlazzar's Avatar
i assume you meant mbc instead of bov?
Old Dec 7, 2011 | 12:57 PM
No sir. The bov is adjustable there is some stuff out there about adjusting but basically all they say is turn it down if u have a lot of compressor surge. I didn't know I mean I know it helps because it's holding better boost after it peaks
Old Dec 7, 2011 | 07:03 PM
Boosted Tuning's Avatar
I run 27psi and have mine tuned fully towards (+). I get some minor flutter in 4th adn 5th, depending on the situation.
The pro of tightening it is putting more preload on the spring so it holds boost better.
The con of tightening it too much, is flutter in high gear, low load situations.
Old Dec 7, 2011 | 09:27 PM
awesome thank you for the info man i may just go all the way to the + then back off a few turns! awesome peaking 30 psi and dropping to 22 psi was getting annoying as hell
svt_lightning01
21
Mar 12, 2019 07:02 PM
SWOLN
Oct 15, 2015 11:07 AM
ridenrunwv
Sep 19, 2015 06:42 PM
honda-guy
19
Aug 9, 2012 02:40 AM
IAmADirtDude
Nov 28, 2010 07:39 PM
