Need info
Old Dec 22, 2011 | 12:00 PM
rrevo9grl's Avatar
Need info
Ok so I purchased my evolution about 3 days ago. The owner before me had it on the track a few times and had this switch installed to allow faster shiffing during a drag. I know it takes a special tool to turn off this switch but I guess my question is, is it bad to be driving the car normally while this switch is on? Because I'm not sure if the slight grind from 4th to 5th is do to the switch and the fact I'm shiffing slower or there actually might be a slight grind in the gear. If there is I'm not worried I can have the tranny rebuilt.
Old Dec 22, 2011 | 12:06 PM
llDemonll's Avatar
What?
Maybe I'm naive, but how will a switch help you shift faster when it's a manual? Placebo effect?
Drifting Away's Avatar
Are you sure its not just a ecu map switch? Pictures?
Old Dec 22, 2011 | 12:16 PM
rrevo9grl's Avatar
Originally Posted by llDemonll
What?
Sorry for the mis-understanding but its called a no lift. It allows faster shiffing bc you don't have to take your foot off the gas
Old Dec 22, 2011 | 12:25 PM
2004EvoVIII's Avatar
I would think that if the switch was installed to allow shifting while gas is down it would be like the dogbox transmissions where you dont have to push in the clutch. You still can push in the clutch if you want, but you have the option NOT to.
Same with this switch - if you're driving it normally and you take your foot off when you shift it like a regular normal manual car it shouldn't damage anything or cause anything to go bad AND you have the option to keep your foot on the gas if you so chose.
I could be wrong, but that's what it sounds like to me.
Old Dec 22, 2011 | 12:29 PM
DSMdynamic's Avatar
Google it, there's a bunch of things that come up. This one seemed kinda helpful..
http://mitsubishiforum.com/forum/mit...-shifts-23369/
Old Dec 22, 2011 | 12:49 PM
thepoint4life23's Avatar
No lift to shift its in your ecu so to turn it off you would need to have a tuner do it or get the ecu flash on your computer and a Tactrix Cable then you can turn it off.
Old Dec 22, 2011 | 01:10 PM
DontStopMe's Avatar
No lift to shift is so you can shift without letting off the throttle. And as stated above, it is flashed on to your ECU.
Unfortunately for you, the grinding you are experiencing would have nothing to do with the NLTS (No lift to shift).
Old Dec 22, 2011 | 01:31 PM
73DatsunZ's Avatar
Yeah... unfortunately I think that grind in the transmission is due to previous "abuse." There are some pretty reputable places to get that fixed near you if you want to address it. Changing your transmission fluid could help soothe it some in the mean time.
Old Dec 22, 2011 | 06:26 PM
rrevo9grl's Avatar
ok thank you all for the helpful tips
KillaYayo
Aug 31, 2016 07:31 PM
lousEVOxmr
Mitsubishi TC-SST Discussion
Feb 12, 2010 09:13 AM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
ramon120
Jun 29, 2005 07:20 PM
theblue
15
Jan 9, 2005 03:42 PM
