Evo running lean..need some help...
Old Dec 26, 2011 | 08:26 AM
mean4g63's Avatar
Ok car runs fine in part throttle and driving around town. The issue is when I get on boost, at around .5 bar the car starts to run leaner...starts in the mid 12s and by the time it hits .7 its in the 13s and over 1 bar its in the 15s. It progressively gets worse from .5 bar on...I have also logged it via Evoscan and it certainly does knock...so my aem wideband is correct.
Anyways here are the things I have done to try to solve this problem...
-installed NEW AEM FPR with gauge
-installed known good walbro 255
-re-wired fuel pump
-checked fuel pump voltage at idle and its a consistent 13.5 volts.
-I also tried adding fuel to my map through ECU flash 1.42..no change.
for reference... my mods are: Map V3 intake manifold, Full blown 70 MM TB, ETS 3.8" garret intercooler, AEM FPR, walbro 255, and removed all emissions evap canisters/solenoids and EGR, AMS exhaust, MAP o2 eliminator DP, GSC S1s, AEM cam gears, and stock turbo..and I think thats it.
Now I am down to possibly clogged injectors? or perhaps for some reason clogged fuel pump filter housing filter? What are my chances if it being either? What is the best way to check my fuel tank return line being clogged? Is there something else I am not thinking of?
Help me in a new direction..Or I might have to go after a filter housing. I really dont want to have to fork out for a new filter housing as those things are like 400 dollars...
Old Dec 26, 2011 | 08:42 AM
Fastone_evo6's Avatar
how is your fulepressure , check that , whit a gauage !
Old Dec 26, 2011 | 08:48 AM
mean4g63's Avatar
well gauge is on the FPR reg, obviously I cannot test it while I am driving.
Old Dec 27, 2011 | 06:42 PM
5speedwtneed's Avatar
So this car is tuned by you?
mrfred
68
Jul 13, 2017 11:22 AM
Masterr
Dec 6, 2016 11:17 PM
Hotsauce101
Jul 23, 2015 11:57 AM
Go_Lancer_Go
Jul 14, 2015 10:29 AM
drewdq
E85 / Ethanol
45
Dec 29, 2008 10:47 PM
