Full Blown Double pumper lean
I have the problem where its leaking fuel up through the cables. And lets stand on idle car Will begin to go lean after à few minutes, i have both pumps running all the time with à drilled syphon, base pressure set to 42 psi! Anybody know what is wrong?
The issue that you're describing isn't new at all to the full blown set-ups. I hate to say it but search. There are quite a few issues with this double pumper and depending on where you go it there can be a few more -
always always always go leans on left handers if you're below about 1/3 of a tank. Due to the way the saddle tank is designed the fuel is kept in two separate sides of the tank and sloshes over so if you're on the gas and go left, you'll go lean.
depending on the previous owner the siphon may be drilled which causes the passenger side of the saddle tank to hold the gas and not be siphoned over.
Leaking out the top through the area where the wires go up
That's just to name a few. Just search, they are not very reliable. I'd say a lot of people try them only to be disappointed and stick with the buschur (like me).
240Z TwinTurbo
37
Dec 9, 2018 08:16 PM
turbocheese
16
Nov 19, 2015 09:16 AM
mrm95
Apr 30, 2015 11:52 AM
NOMIEZVR4
May 11, 2014 07:54 PM
