Help me install a A/F gauge
Old Jan 10, 2012 | 04:57 PM
WolfsFang's Avatar
Ok a few months ago i got a free JDM (ebay brand) A/F gauge. Recently i've been running lean thanks to my egr valve. I replaced that and I think that did the trick, but since i found this i want to install it. The only problem is that this dosent come with a wideband sensor. Just the gauge with red, black, and green wires. Is their anyway to wire this without a wideband sensor? If not then ill just wait a little bit and save up for a AEM gauge. Im not planning to keep this gauge for ever, i just want to use it until i got enough for a AEM gauge.
Old Jan 10, 2012 | 05:01 PM
shrtstuff89's Avatar
No you cant. The red black white and blue wires are there for power ground dimmer and something else.
Old Jan 10, 2012 | 05:03 PM
WolfsFang's Avatar
i know this and the green wire is for A/F.
Old Jan 10, 2012 | 06:00 PM
WolfsFang's Avatar
let me reword this so people can understand what im saying. From what iv been told you can use the stock O2 sensor as a wideband. Not the most accurate but it will have to do for now. How would i go about doing this? Do I use the O2 wire that goes into the ECU or else?
Old Jan 10, 2012 | 06:42 PM
06RedRalli's Avatar
The stock o2 is a narrowband not a wideband. So its useless to hook up without an actual wideband sensor.
Old Jan 10, 2012 | 06:47 PM
boostless's Avatar
This. Save up for the AEM, Innovate or whatever
Old Jan 10, 2012 | 07:16 PM
WolfsFang's Avatar
Looks like im saving for a true wideband then. Would it be ok to replace the rear O2 sensor with the wideband? I got a stock DP and i dont feel like drilling through it. I am planning on getting a new DP during the summer.
Old Jan 10, 2012 | 07:58 PM
06RedRalli's Avatar
Going to have to convert your ecu rom to tephra v7 to disable the rear o2 to replace it with the wideband sensor in its place. Or easiest way is to weld a bung into your dp.
Old Jan 11, 2012 | 12:01 AM
WolfsFang's Avatar
wait why cant i just remove my rear O2 and replace it with the wideband sensor?
Old Jan 11, 2012 | 08:27 AM
06RedRalli's Avatar
Because the stock ecu uses the front and rear o2 to make sure one or the other is working properly. But you can disable the rear o2 in the ecu rom so it doesn't even look for it anymore which allows you to plug the wideband in, in it's place instead.
Old Jan 11, 2012 | 04:36 PM
egis's Avatar
most of mechanical shops should not charge u more then $30 for the welding and bung.personally i paid $5 for the bung and $25 for the labor.install that wideband properly first time and forget the headaches.
Old Jan 11, 2012 | 06:42 PM
WolfsFang's Avatar
Well im getting a new one in a few months so I don't want to sell asteroid money on my stock one.
Old Jan 11, 2012 | 06:43 PM
WolfsFang's Avatar
Went to say waste money, can't edit my post on my phone
vipevo9
Oct 2, 2013 09:24 PM
bryonboals
Sep 8, 2013 08:12 PM
ProPilot04
Jul 19, 2011 08:58 PM
AutoMotoSports
Automotosports - Illinois
37
Jan 21, 2010 08:11 AM
ddubdb3
Dec 10, 2006 05:12 PM
