Lower IC piping worth it?
Old Jan 12, 2012 | 04:42 PM
escodotcarter's Avatar
Go with the MUSE licp. I have it and its a very nice piece. Polished and fits perfect. best price of the bunch.
Old Jan 12, 2012 | 04:47 PM
BigT's Avatar
I picked up a muse unit. I picked up 4 whp peak, but 15whp in the curve. (between 5500 and 6500rpm) This was tested against an ebay LICP which is a copy of the AMS.
Old Jan 12, 2012 | 05:05 PM
Waldo's Avatar
Where can I find the muse LICP?
Old Jan 12, 2012 | 05:17 PM
10isace's Avatar
This is about what I found with my ETS.
Old Jan 12, 2012 | 05:26 PM
Raptord's Avatar
Originally Posted by Waldo
Does the ETS come with a mounting bracket?
No, doesn't need one.
Old Jan 12, 2012 | 05:48 PM
rush63's Avatar
Thanks man. I'm going to check in to all of those for sure.
If you had to pick one, what would you say is the best one?
Anyone have dynographs for comparison?
I have MAP's but have not installed it yet.
ETS had a comparison among their LICP 1, LICP 2 and stock (not sure) but I don't think somebody has done a comparison among different brands.
Old Jan 12, 2012 | 06:07 PM
3K's Avatar
3K
MAP licp
Also uicp's are not just for looks. The stock rubber ones blow up like ballons under boost.
Old Jan 12, 2012 | 06:13 PM
Mistaken's Avatar
ETS or AMS...
Find a used one on here. I got my AMS for cheeeeaaaaap!
Old Jan 12, 2012 | 07:21 PM
10isace's Avatar
ETS makes a titanium one. It's a little more $. My ETS LICP is heavier than my OEM one, at least that's what it felt like.
Old Jan 12, 2012 | 07:26 PM
Ryuartz's Avatar
https://www.evolutionm.net/forums/ev...best-licp.html
Hope this helps
Old Jan 13, 2012 | 12:59 AM
FJF's Avatar
FJF
Not worth it to me, as I've yet to see anything showing a significant benefit on a stock-ish car in the +5 years I've been here.
Old Jan 13, 2012 | 03:44 AM
bigben's Avatar
This is definitely an improvement, whether you want to acknowledge it or not. The routing is shorter and much less restrictive. C'mon, I've been here longer than you, and even I know this
Uploaded with ImageShack.us
Old Jan 13, 2012 | 04:00 AM
Turbofig's Avatar
Thanks for the replys!
Do you know which companies don't taper in the middle?
I was looking at an AGP one
I have the AGP one and I really like it. Here are a few pics I painted mine black. I liked the fact that it was reasonably priced at $169 and it has a bracket that allows you to mount to the radiator support with a self tapping screw so its less likely to blow off under boost. Any licp will be fine inmo but this one has a decent $$. Happy shopping!
Old Jan 13, 2012 | 04:31 AM
FJF's Avatar
FJF
OK, it looks a lot better and the point of restriction is now at the coupler vs farther down the pipe, and there are no support brackets. I'd still like to see a dynograph on a stock-ish car.
Edit: Just so there's no misunderstanding, I don't really care if folks buy an aftermarket LICP for their cars.
Old Jan 13, 2012 | 05:09 AM
bigben's Avatar
ETS does have some dyno info on the page for their LICP:
http://www.extremeturbosystems.com/E...oler-Pipe.html
