stock piston ring specs
Old Jan 18, 2012 | 09:46 AM
CrawlinTBSS's Avatar
anyone know what size stock piston rings i need to buy for my rebuild?
stock 2004 4g63 from Evo 8. Need mm specs on thickness of the rings im needing.
i thought it was 1.2 , 1.2 , 2.8mm and my bottom oil rings arent fitting, but everything else does. couldnt find any specs in the evo manual either.
Thanks
Old Jan 18, 2012 | 11:43 AM
Mauricio Evo IV's Avatar
I don´t know if you can use aftermarket rings??
I leave a link:
http://www.extremepsi.com/store/prod...0&cat=0&page=1
Old Jan 18, 2012 | 01:06 PM
Those are incorrect as well. the 2.8mm oil ring is way to large. its gotta be like 1.8 max.
dealer has correct ones for 80/set, for one piston. EEEKs.
our local supplier found a set for 120$ so should be good.
Igaly1021
Aug 15, 2016 07:56 PM
kylefowlie
Dec 21, 2015 11:54 AM
konstantinosIX
20
Oct 26, 2008 06:09 PM
MikSchultzy
Oct 4, 2007 07:37 PM
94AWDcoupe
14
Feb 6, 2006 08:58 PM
