Running on cylinders 1&4 only, help!
Old Jan 24, 2012 | 01:37 PM
420a-t's Avatar
I am at a loss. I changed some stuff up on my car (turbo, cleaned the injectors, new intake, etc.) and now when I start it up, it only runs on clyinders 1 and 4.
I have ensured that it is a fuel issue due to the plugs being brand new and zero gas on them when I pulled them out, swapped coils from 2&3 to 1&4, 2&3 still do not want to fire. What else could it be on an evo?
I tested the wiring for the CAS, and it is as follows:
11.88v
3.78v
.06v
This is with the key in the "ON" position. Are these good numbers?
Thanks for any and all help,
Josh
Old Jan 24, 2012 | 02:01 PM
MechTech's Avatar
Are u getting power to the coil? Did u check fuses?
Old Jan 24, 2012 | 02:20 PM
420a-t's Avatar
11.66 Volts (cold outside, small battery) to the coil, Checked continuity for the ground as well, and the third pin is getting .06v as well. I checked all fuses that are maked as an engine fuse in the engine bay and in the cockpit, anything else I should try?
Old Jan 24, 2012 | 02:23 PM
evolvd276's Avatar
if its a fuel issue why worry about spark ? also have you checked the injectors if they are getting pulse?
Old Jan 24, 2012 | 02:31 PM
MechTech's Avatar
I took "not firing" as no spark as in the coil not firing. How do you know its only running on 1&4? Misfire counts? Did u try swapping injectors around? Do you have access to a scope?
Old Jan 24, 2012 | 02:53 PM
420a-t's Avatar
I just checked if my injectors were getting signal via a noid light, and they are both getting signal as well....
My spark plugs are completely dry and brand new looking everytime I pull them out which is why I believe its no fuel, but they are getting a signal to open.
It just seems weird to me that both cylinders that are having the same probelm are on the same coil pack as well...
Old Jan 24, 2012 | 02:54 PM
420a-t's Avatar
If I unplug 1 or 4 via injector clips or the coil pack that runs 1&4 the car dies, but if I unplug the coil that runs 2&3 the car sounds no different.
Old Jan 24, 2012 | 04:26 PM
MechTech's Avatar
How did you clean ur injectors? in detail
Old Jan 24, 2012 | 04:34 PM
deylag's Avatar
Do you have a compression tester?
Old Jan 24, 2012 | 04:56 PM
420a-t's Avatar
yeah, everything was perfect before I swapped turbos, it was about 160 across the board.
I just swapped injectors 2&3 (the cylinders that were not getting fuel) with injectors that were in cylinders 1&4 (the only two that were working correctly) and found that the injectors I moved from 2&3 to 1&4 are not working now, which leads me to believe that the injectors are not working correctly.
How do I troubleshoot my injectors? Why would two of them be bad at the same time?
Before I started my car today, it was sitting until September with e85 in the tank, which I drained completely, and also removed the injectors, soaked them in pump gas, and made sure I didnt see any black goo anywhere.
Where do I go from here?
Thanks
Old Jan 24, 2012 | 07:19 PM
420a-t's Avatar
Figured it out. Threw some stock injectors in, and it runs perfectly. Need to send my FIC's out for cleaning I guess. Weird that two went bad at the same time too...
Thanks for the help
4g63jdm
May 11, 2016 09:25 AM
evo4mad
May 5, 2015 06:22 PM
foxbear2277
33
Dec 7, 2014 03:40 AM
Kidloco51
Oct 9, 2007 07:44 PM
iodine23
Apr 8, 2004 08:50 AM
