wiring harness question ?
Old Jan 24, 2012 | 05:03 PM
apexisilver8gsr's Avatar
ok the problem was " dead injector one orange wire"
Old Jan 24, 2012 | 11:48 PM
domestickillaAR's Avatar
i hope you really dont need a new harness i replaced the one in my 2G after the shop that built my last motor destroyed it and it cost me 1k..for the DSM they call it a controll harness
Old Jan 25, 2012 | 08:20 AM
thats what i was hoping for ... but i think ill have to because for some reason im not getting signal for injector #1, new ecu, new resistor box, new injectors, new rail and apr, new fuel pump i have compression the bottom end is fairly new and still no luck from what i researched alot of early 03 evos have wiring problems ...
Old Jan 25, 2012 | 09:20 AM
barneyb's Avatar
Build that one wire all the way back to the ECU.
Old Jan 25, 2012 | 09:46 PM
ok man i will try that !
Old Jan 26, 2012 | 08:11 PM
so today i got little bit of time to mess with a car, i did ran new wires from a injector clip to ECU pin outs, and still nothing.. so my next question is how often do plug wires go out ?? i do have brand new plugs in and newer coils. i havent checked my spark yet but i will tomorrow
Old Jan 27, 2012 | 04:18 AM
turboey's Avatar
why type of electrical issues? unless it caught fire or got destroyed by a rodent or something, harness replacement is generally needed
Old Jan 27, 2012 | 04:19 AM
turboey's Avatar
also try testing for continuity from your injector wires on back to the ecm. if its solid then move over to checking resistance
Old Jan 27, 2012 | 04:32 AM
SaulHudson's Avatar
Did you check to see if you blew a capacitor or even blew some solders in your ECU?
Old Jan 29, 2012 | 12:36 PM
ok here is a little update, i still haven't check volts yet( waiting for my buddy to drop off a volt meter) but i checked spark and fuel, it gets fuel in all 4 cyl and cyl 1 does not get spark or maybe really weak spark, seems like other 3 plugs got weak spark too since all plugs were wet ( fuel) when i tool them out. i did replaced coils and wires and also switched them around still no luck
Old Jan 30, 2012 | 05:17 PM
Anybody else have any ideas ?
Old Jan 30, 2012 | 09:19 PM
SaulHudson's Avatar
So your plugs are getting fuel fouled. Did you check the injector resistor pack and relay? When you check fuel, did it mist? It should be a really light mist if its spraying a lot then that's why they are getting fouled. Clean the plugs with a wire brush. You are sure the coil packs are in correctly? They only go in one way.
Old Jan 31, 2012 | 01:45 PM
ok ill double check injectors tomorrow. i got a new resistor back for it along with a new ECU. i checked my volts for both coils CAS and 02 sensor today and its showing 11.6 on "ON" position. and yes coils are in correctly
Old Feb 1, 2012 | 02:16 PM
ok so i checked all the rest of the sensors and clips and its 11.6 volts, i checked the spark and its all good, i pulled the rail with injectors off and check if they were spraying and first one wasn't, i swapped the injectors still nothing, i swapped the injectors clips( as in i put first one on second one ) and second injectors wasn't spraying .... so i checked volts on it and its 11.6.
so what else could it be ??
Old Feb 1, 2012 | 02:53 PM
Vivid Racing's Avatar
You should have more than that. What's the voltage at the battery?
I'm having trouble understanding what you posted though... Are you saying that when injector 1 was moved to position 2, it still did not spray? If so, it's a faulty injector.
