Best Boost Controller?
Old Jan 30, 2012 | 03:04 PM
lanberg's Avatar
I am looking for a boost controller and gauges, and I was wondering if anyone has this boost controller http://www.lancershop.com/customer/p...5&cat=4&page=1
Is it worth the 300 bucks? and is it easy to use? If I want a 400hp street car will i need to exceed 29 psi or should i just about be okay?
Old Jan 30, 2012 | 03:41 PM
notjdm05MR's Avatar
You will not need that to exceed 29 PSI. You can do that with a manual boost controller. Also you shouldn't base your goals on a certain boost level!
Old Jan 30, 2012 | 03:45 PM
sparky's Avatar
Do you want a manual boost controller, or an electronic boost controller? There is a third option worth mentioning here: You could also use modified ECU controlled boost with a three-port boost solenoid.
I don't want to rag on this particular AEM unit. But, I think that I have seen a few negative opinions by users on this forum. Maybe someone else will chime in as I have never used this piece myself. Having said that, you should always try a search on any product before deciding to make a purchase.
Finally, avoid LancerShop like the plague and instead deal only with vendors that are actively involved and participate in the Evo community and contribute on our forum.
Old Jan 30, 2012 | 03:58 PM
EmeryatSTM's Avatar
We use Hallman Pro MBC's in all the cars we build here including Ricer.
They can be found here.
http://www.streettunedmotorsports.co...ccessories.htm
Old Jan 30, 2012 | 06:59 PM
SmurfZilla's Avatar
Get an AEM Tru Boost. Its like a manual electronic boost controller. Buy mine. LOL.
Old Jan 30, 2012 | 09:21 PM
73DatsunZ's Avatar
Seriously get a Hallman.
Old Jan 30, 2012 | 09:35 PM
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
I'm happy with my HBC ..... and if its good enough for ricer its good enough for me.
Old Jan 31, 2012 | 12:01 AM
CJ2X's Avatar
I'm surprised no one's recommended a 3 port.. I got a Hallman Pro but I'm switching to a GM 3 port.
http://www.maperformance.com/grimmsp...-ebcs-evo.html
I would stay away from that Tru boost.. I had one on my Evo 5 and it was a piece of junk.
Old Jan 31, 2012 | 01:08 AM
evilempire76's Avatar
I like my Grimmspeed 3 port using ecu controlled boost.
Old Jan 31, 2012 | 05:44 AM
Danner's Avatar
Grimspeed mbc. Quality product.
http://www.grimmspeed.com/catalog/pr...roducts_id=165
Old Jan 31, 2012 | 06:06 AM
Revo15's Avatar
HALLMAN...Handsdown!
Old Jan 31, 2012 | 06:24 AM
Mauricio Evo IV's Avatar
Grimmspeed MBC... but, I´m switching to a grimmspeed 3 port in the next months!
Old Jan 31, 2012 | 06:30 AM
chu's Avatar
chu
Depends on whether you want to get a manual boost controller, or run ECU boost. There are positives and negatives to both methods. I've ran both setups; Hallman Pro RX for manual, and Perrin EBCS w/ JDM 3 bar for ecu boost control.
Old Jan 31, 2012 | 06:33 AM
Alpha X's Avatar
Can't go wrong with a Hallman
Old Jan 31, 2012 | 06:34 AM
wjamyers's Avatar
when i researched MBCs a few months back I decided on Forge. I plan on set and forget so I don't want a knob in the cabin some idle person could crank on that could cause me problems.
