my car only hits 11psi?
Old Feb 1, 2012 | 03:56 PM
kadir07's Avatar
megan headers are pretty good, why u say they suck? lol its way better then the stock ones.
also i did pull the wsg of and it went to 20 psi..... when i put the mbc on it went downn.
Old Feb 1, 2012 | 03:57 PM
kadir07's Avatar
all the vacuum lines are connected...
Old Feb 1, 2012 | 04:11 PM
EvoJoeIX's Avatar
Im just gonna leave that alone
Old Feb 1, 2012 | 04:18 PM
sparky's Avatar
...i took off the mbc and took the car in boost it went over 20 psi... so i guess the wastegate is ajusted normaly then?
When you disconnected and removed the MBC as per your quote above...you were left with two open ended hoses, one of which had been connected to the side port on your MBC and the other hose which had been connected to the bottom port on your MBC, right?
When you had your MBC hooked up initially when boosting just 11 PSI, had the hose connected to the bottom port on the MBC been connected directly to the compressor discharge pipe's nipple? Secondly, had the second hose which was connected to the MBC's side port been hooked up to the port on the WGA?
Once you disconnected your MBC, what did you do with the two open hose ends? Did you plug them? Did you then proceed to connect the port on the WGA to the port on the turbocharger's compressor discharge pipe with a single length of hose?
What I am trying to get at is...how did you hook up the boost/vacuum hoses that had been connected to the MBC? Or better yet, how did you hook the hoses up when you got that 20 PSI reading? I am curious.
Old Feb 1, 2012 | 04:31 PM
boostedwrx's Avatar
99% of the "my car only boosts to 11-15psi" threads are WGA and/or MBC.
Old Feb 1, 2012 | 04:35 PM
sparky's Avatar
That's for sure! I am trying to visualize exactly how he had his boost/vacuum lines hooked up when he boosted to 20 PSI. By contrast it would be helpful to know exactly how he had his MBC hooked up when only boosting 11 PSI. A picture is worth a thousand words.
Old Feb 1, 2012 | 04:39 PM
sparky's Avatar
well what about when i took off the mbc and took the car in boost it went over 20 psi it didnt spike it was there for like a sec untill i took my foot of gas... i guess the wastegate is ajusted normaly then?
We cannot assume that your WG was "properly" adjusted based on the info that you have provided so far.
Old Feb 1, 2012 | 04:47 PM
sparky's Avatar
If your WG spring pressure was adjusted to 20 PSI...then the installation of an MBC correctly into the plumbing could not possibly lower boost down to the 11 PSI level. No way.
An MBC cannot adjust boost LOWER than the actual setting of the WG spring pressure. A MBC can only raise boost upward above that spring pressure setting and/or lower it down to that setting...no lower.
So, if spring pressure is set at eleven PSI then a MBC can only raise boost up above 11 PSI. Likewise if spring pressure is 11 PSI a MBC cannot lower boost below 11 PSI. That's just the way it is.
So, if spring pressure were adjusted to 20 PSI then you could not lower boost down to 11 PSI with your MBC adjustment knob. Nor could you lower boost down below 20 PSI, by merely installing a MBC correctly into the plumbing. Is this clear?
Old Feb 1, 2012 | 08:56 PM
kadir07's Avatar
The side port on the mbc goes to the wastegate, the bottom one goes to the bov hose in a three way connection. But when i took off the mbc (just disconnected the hoses off it) and drove the car on the highway i didnt plug the wga hose and the bottom hose no where i just left them in the engine bay with out the mbc there... because i talked to this guy who tunes evos and he told me to do that and to take it in 5th gear at 4000rpm and see if the boost goes up over 10psi.. and it did it went to 22-25 ishh untill i let off the gas and the psi gauge just turned off so i stoped and reconnected this hose thats connected on the intake manifold i put it back in and gauge turn back on . so i came back home and connected the mbc on and turned the boost all the way on + and tryed it and it was back to 11 psi... this is really wierdd. idk wtf is up with it..
Old Feb 1, 2012 | 09:02 PM
kadir07's Avatar
When i was on the high way with out the mbc i didnt floor it tho i just hit the gas alittle untill iit reached 20+ psi, if i had it floored the turbo would of maxed out..
Old Feb 1, 2012 | 09:40 PM
usnevo8's Avatar
im not trying to argue or start one either but megan likes to crack, and their welds arent that great.. the stock exhaust manifold ported is 10X better.. ive even heard the port on them is even smaller than the stocker.. i have a megan right now and i just got the stock ported and putting it back on..
aside from that did you get your problem fixed?
if you read on here and study enough you'll learn everything you need to know to fix your car when its a simple issue
Old Feb 1, 2012 | 10:14 PM
kadir07's Avatar
oh idk well i just bought my header just waiting for it to come... the guy told me he drove it for 15-20 k miles and no issues.... also megan header is bigger then the stock one.. i checked on youtube.. but it if cracks ill get a new one haha..... but no i did not idk wtf is up with it.
Old Feb 3, 2012 | 11:55 AM
Redoctane's Avatar
boost valve? those go bad and break sometime
Old Feb 3, 2012 | 01:25 PM
SpinALL4s's Avatar
what kind of boost controller also is the boost gauge tapped at the right area?
Old Feb 3, 2012 | 02:26 PM
kadir07's Avatar
the boost gauge is correctly put on it... the vac works, just doesnt want go over 11 psi... i have the hallman mbc, i will take some pics and post on here...
Dapper Dan
16
Feb 26, 2017 08:00 AM
elhalisf
36
Nov 19, 2012 02:06 PM
furiousd
Feb 27, 2010 06:28 AM
rudy91889
Jun 4, 2009 02:52 PM
vampire
17
Jul 27, 2006 08:24 AM
