Cleaning Maf help...
Old May 8, 2012 | 09:25 PM
kyoo's Avatar
wow.. i've run a kind of crappy k&n filter for a lot longer than i should have without cleaning before i switched to the amsoil filter, curious to see how t'll look
Old May 8, 2012 | 10:13 PM
Chef-j's Avatar
Originally Posted by polish_pounder
that picture is after like 20 min of spraying my maf lol. only half the gunk is in that picture... but no before the install it was the stock intake with a cone on it not the box. the cone was rusted to hell tho....
after install of my perrin my tune got all messed up. my AFRs at WOT went from 10.9-11.2 to 11.8-12.5.... and i cant get retuned cause i need a clutch lol
Dang... Thats dirty.
Old May 8, 2012 | 10:34 PM
Runker's Avatar
Can't wait for this weekend. Im going to clean my mass airflow sensor, seafoam my intake, change my tranny fluid and radiator fluid, swap out my intake filter, change my spark plugs and wax my car.
Old May 8, 2012 | 10:39 PM
4RETECH's Avatar
Just wondering if anyone ever read the warnings on the CrC can,LOL
Not to be used with Mitsubishi
So I guess it's not our MAF they are talking about?
Old May 9, 2012 | 03:49 AM
bigben's Avatar
I clean my MAF every oil change (2-3 months) with no adverse effects. I've been doing that for well over a year now.
Old May 9, 2012 | 06:08 AM
nirvancol's Avatar
Yeah I was going to use this stuff to clean mine until I read the warning. And they definitely are talking about our MAF. It specifically mentions Karman Vortex type MAFs which is what the evo has. I searched around and found posts on other boards from people who damaged their Karman Vortex type MAF after using it. I'm not risking it, but I don't know what the recommended cleaning method is
Old May 9, 2012 | 06:51 AM
gsrboi80's Avatar
It will not damage your MAF. Ive used it for more than 5 yrs without issue. My guess (Just a guess) is the reason for the warning w/Karmen Vortex MAF is the resistor seen inside the MAF can be broken by using the straw with a direct stream on the thin wire or by hitting the resistor.
Hold the can back a few inches = Win
Again many here have used it for years without one reported MAF damaged that I have ever read
Old May 9, 2012 | 06:52 AM
gsrboi80's Avatar
Stupid double post
Old May 9, 2012 | 07:35 AM
kyoo's Avatar
wow that's surprising... makes me kind of nervous about cleaning mine now.. will elbow grease do?
or can you spray it on a paper towel first and then just wipe?
Old May 9, 2012 | 07:46 AM
okevolutionVIII's Avatar
You really have nothing to worry about if you don't use the straw and hold the can at a distance. A toothbrush to clean the walls and a Q-tip on the sensor will be fine as well.
Old May 9, 2012 | 09:21 AM
Chef-j's Avatar
Which means it is ok to some of spray can be on sensor or wire( whatever u call)? I think confusing me is other cars that i cleaned, it requires to remove maf sensor.
Old May 9, 2012 | 09:37 AM
vortico's Avatar
I used the CRC cleaner to clean my MAF recent (had the same filter as OP actually, but it was no where near that bad on the filter or maf, switched to Amsoil filter now =) ). Anyway, as it has been said don't use the little tube and spray directly on the orange wire. Spray form a bit of a distance and you are fine. Its not the chemical that has issues with the MAF but the pressure and volume of cleaner hitting it if you use the tube directly on it.
Then just make 100% sure its completely dry before you connect it.
Old May 9, 2012 | 09:56 AM
Chef-j's Avatar
^ awesome!
Old May 9, 2012 | 10:06 AM
suekie's Avatar
wow, that is dirty. Don't let it get that bad next time
Old May 9, 2012 | 10:38 AM
deylag's Avatar
Wow that MAF was super dirty. I have a little dirt on the goldish column right before the resistor. I think it would be better if I used a q-tip to clean it. Right?
