Iac question post-search
Old Feb 2, 2012 | 01:06 PM
NattyMyst1c's Avatar
My question is after installing a new/ish one is there any type of calibrating or anything needing to be done?
I bought one off another owner(evo9 putting on my 8) stating it works perfect and after starting the car it idles worse. If its faulty Ill find him, but maybe there's something else. Any help appreciated
I know it's been talked about over and over in various threads.
This questions simple and haven't seen it. Good answer and when it's over with and someone else can benefit from it hopefully
Old Feb 2, 2012 | 01:08 PM
EvoDan2004's Avatar
mitsu uses the same P/N for the evo 8/9 sensor. so my guess is there the same.
Old Feb 4, 2012 | 05:27 AM
4RETECH's Avatar
Basically you will have to do an idle learn. I would disconnect the battery and let idle for a while, then drive it around for two days so it re learns the parameters.
Old Feb 4, 2012 | 07:54 AM
snafufx's Avatar
If you have evoscan, turn it to SAS mode, adjust your BISS screw to 850 (whatever stock is) or so rpms, turn off SAS mode, disconnect and wait for the idle to turn to whatever your flash is set to hit. I had to basically do the entire base idle reset to get my IAC to work properly. Worth a shot. If all else fails, raise the idle on your flash, not the BISS screw. Good luck.
mrm95
Sep 2, 2013 11:46 PM
DaGermanEvo9
Nov 21, 2010 09:30 PM
idriveanevo
54
May 28, 2009 12:07 AM
Gts_BlackJoker
Lancer Engine Tech
Feb 16, 2009 07:59 PM
GTisRule
Northwest Region
13
Dec 1, 2006 11:26 AM
