Car stalls at stop light. idle dip. Won't start without gas
Old Feb 6, 2012 | 01:49 PM
bubba17's Avatar
hook a scan tool up to it and see what codes its throwing and research them. take it to autozone and have them scan it or if u have a scan tool do it yourself
Old Feb 6, 2012 | 03:16 PM
Dube's Avatar
Boost leak and possibly adjustment of the BISS screw on your TB. Adjust it a quarter turn counter-clockwise or clockwise, see if it gets better.
Old Feb 6, 2012 | 03:35 PM
SilverShadow03's Avatar
I had a similar issue and it turned out to be my IAC. The o-ring, visible once the IAC is removed, can go bad or the teeth sometimes break off....causing similar symptoms.
My car was fine (fine as in staying on) as long as my foot was on the gas pedal...If I wanted to idle to a stop with car in neutral or just idling at a stoplight with my foot off the gas pedal, my car would die.
I've had to replace my IAC 3 times already.
Good luck and keep us posted.
Old Feb 6, 2012 | 03:57 PM
randomevo's Avatar
3 times? good grief that sux. those things aren't cheap. I have to find the pic I took of my iac, but the teeth looked fine. Will check the voltage tomorrow and see if it lines up with what it should be.
Anyone have a pic of a clean one?
Old Feb 6, 2012 | 04:40 PM
vmrevo9's Avatar
Veteran: Air Force
i just replaced an IAC on my friends 8. it measured fine and the teeth looked intact. it even clicked and moved when the power was reset.
the car would die at stops and and it would idle funny as well.
i replaced the IAC and its all good for now.
i bought mine on ebay for 55 shipped.
dac001's Avatar
post 151 https://www.evolutionm.net/forums/ev...ease-help.html
Old Feb 6, 2012 | 04:54 PM
randomevo's Avatar
Originally Posted by dac001
I've been following that thread. It's not the same problem as mine. Its worth a look, but when my car idles at the normal level it sounds fine,
Old Feb 6, 2012 | 05:18 PM
phi79's Avatar
1++
Originally Posted by vmrevo9
i just replaced an iac on my friends 8. It measured fine and the teeth looked intact. It even clicked and moved when the power was reset.
The car would die at stops and and it would idle funny as well.
I replaced the iac and its all good for now.
I bought mine on ebay for 55 shipped.
Old Feb 7, 2012 | 12:34 PM
ViciousLSD's Avatar
Try to borrow a MAP sensor
Old Feb 7, 2012 | 09:11 PM
NattyMyst1c's Avatar
Having the same problem. My cars my daily for both jobs of which I use the car for work. Don't have time to wait and work on everything so brought it to a respectable shop in Illinois my friends go to. Should get an update tomorrow I'll let you know what it ends up being. From my last week and a half of searching forums and talking to fellow Evo owners I've noticed it's been showin up alot in 03s(including mine).
Once again I'll keep this thread updated. I miss driving my Evo :,(
Old Feb 7, 2012 | 09:19 PM
AWD96's Avatar
I am willing to bet my 3rd testy that its your IAC. I found one on here BNIB OEM for $55 shipped a few months back. She idles like a champ now. Take the IAC out and look at the motor, theres teeth on it that engage the unit that strip out over time. People that used Alcohol/Meth injection had issues with it more commonly because it would break down the plastic.
Old Feb 8, 2012 | 04:42 AM
randomevo's Avatar
well i ordered an iac so I'll update once it comes in. Would love to know where you found one for 55 bnib though. thats crazy talk
Old Feb 9, 2012 | 08:29 PM
It was crank walk ftl. Oil after one day of driving was discolored. Car still dies/drops rpm disengaging clutch.
Old Feb 10, 2012 | 12:15 PM
Scofflaw's Avatar
Does anyone know where to find a new o-ring for the IAC? I can't find any without the actual IAC.
Old Feb 10, 2012 | 12:58 PM
Try calling your local junkyards and seeing if they have any IAC's from these cars and try the o-rings....
(FOUND FROM ANOTHER THREAD) = Also, these should work in replacement of your evo 8/9 IAC....easier to find than a wrecked evo at a junk yard and a lot cheaper.
2.4L SOHC
2000-2003 Mitsubishi Eclipse
2001-2004 Chrysler Sebring
2001-2004 Dodge Stratus
1999-2003 Mitsubishi Galant
