Car stalls at stop light. idle dip. Won't start without gas
Old Apr 10, 2012 | 08:37 AM
  #46
4RETECH's Avatar
Just incase anyone wanted a new one.
http://www.amazon.com/MD628318-AC571...4072124&sr=1-2
Not OEM, but works.
I had to get another one for my Evo, seems to stall coming to a stop now.
This will be my 3rd so every 100K is fine for me, LOL
Old May 24, 2012 | 12:17 AM
  #47
Blitz_b9's Avatar
http://www.ebay.com/itm/2006-MITSUBI...7ba02c&vxp=mtr
hi, will this evo 9 idle control valve fit in my evo 6??
Old May 24, 2012 | 06:01 AM
  #48
Scofflaw's Avatar
Does your TB look like this?
This one here is an evo 8/9 :
Maybe someone with a keen eye can tell you if the screw holes match.
Old Dec 16, 2015 | 12:14 PM
  #49
mit2.4's Avatar
Originally Posted by randomevo
well i ordered an iac so I'll update once it comes in. Would love to know where you found one for 55 bnib though. thats crazy talk
I know this thread is a little long in the tooth but thought I'd shime in with my 2¢.. Not sure if this is same as Mit but it's 12.95 shipped...BUT..I went through 2 cheap ones in under 10K mi....$5 junk yard one has been on for 2 years and about 20K miles.. http://www.ebay.com/itm/NEW-IDLE-AIR...9Uc0cY&vxp=mtr
Old Dec 16, 2015 | 01:18 PM
  #50
iatmapotcmst's Avatar
I don't know if that is the correct one, I bought the one off of amazon because I am having the same issue. It gets here Friday.
Old Dec 17, 2016 | 08:20 PM
  #51
truthdweller's Avatar
Veteran: Navy
randomevo, et al...I'm going to say it's your MAP sensor....
Identical problems for me, sudden onset of symptoms, car shutting off when idling, pulling into driveways etc., even on the highways when foot off the gas, etc, etc...no codes, running like crap, can't get it started unless foot on the gas/floor, flooded symptoms, etc, etc. Checked everything you've already checked, chasing a ghost it seemed like, until...
I took off the MAP to inspect it, not much to see other than testing it. But before I went that route, the o-ring seemed to be a bit brittle and loose, so went to Ace Hardware and picked up a couple, one the right size and one a gauge larger. Well, if you haven't already anticipated, I tried the larger gauge and ended up busting one of the mounting tabs off. Now I had to spend the $90 or so whether it was faulty or not!
Solution:
After replacing the sensor, the car went back to normal. I hope this solves the issue for you as well!
Old Dec 17, 2016 | 10:57 PM
  #52
barneyb's Avatar
This sounds like IAC to me. They usually don't just quit, they suffer a lingering death. But if the car bogs while driving at steady speed I'd suspect the O2 sensor.
Old Dec 18, 2016 | 11:11 AM
  #53
Klaiceps's Avatar
Car bogging at steady speed is also symptomatic of a failing MAP sensor. It's really tough to pinpoint these driveability issues sometimes that I have resorted to keeping extra sensors/IACV on hand just in case.
dsmtalontsi95
Aug 25, 2018 05:44 AM
Evo1001
May 30, 2017 06:42 PM
irwintan27
Nov 10, 2016 09:37 AM
GaminKWB
Lancer Engine Management / Tuning Forums
15
Oct 21, 2016 03:48 PM
