E85 or pump gas?
Old Feb 9, 2012 | 10:18 AM
evo8426's Avatar
Originally Posted by SDevo13
Keep in mind, with e85 you need to be careful where you buy fuel, and you need to make sure you don't let the car sit for any extended period. ID has a lengthy article on the havoc it can cause. Not saying you shouldn't do it, just know it comes with some added 'work' to keep things running right.
That being said. I vote yes (my second map is e98 ^_^ )
I'm not sure how e85 is around your area but I've gotten it in 2 different states at 5 different locations and it always ran the same. So as long as its not a Mom&Pops type gas station I wouldn't worry. Also, my car has sat for several weeks with e85 in the tank and still ran the same as it did before sitting.
Old Feb 9, 2012 | 10:26 AM
Silversmasher8's Avatar
Got my e85 tune set up in 2 weeks. Can't wait..
Old Feb 9, 2012 | 10:36 AM
binky's Avatar
Question to everyone who now runs E85.
I plan on doing an E85 tune this spring. With that said, ever since Mellon Tuning posted that thread about his head lifting due to his injectors becoming clogged, I've had second thoughts.
Are you guys worried about this happening to your car? Has it happened to your car? What do you do to prevent or help prevent the gunk build up?
I've been considering just using C16, as it's actually easier to get than E85 is (since I'm closer to a race gas station....yeah they don't carry E85). If I got an E85 tune, realistically, I would only use it when I go to the drag strip, unless a station opens closer to me.
-Bink
Old Feb 9, 2012 | 10:41 AM
4bangerlover's Avatar
-Bink
I've heard to run a tank full of 93 to clean out the system just to be better safe then sorry.
Old Feb 9, 2012 | 10:47 AM
SDevo13's Avatar
^^ this is what I am talking about. Letting the car sit w/ e85 can rust the injectors because the alcohol absorbs water from the air. If your car is going to sit all winter, run a full tank (if not two or 3) of pump gas through it BEFORE you let it sit. I killed a set of id2000's last year leaving e85 in it (luckily ID replaced them). ID says that even allowing the car can sit for a week can cause this under the right conditions. This doesn't include the gunk issue experienced by mellon. Basically plan on running a tank of 93/91 through for every 4-5 of e85 or every 2 months. You may get lucky not doing it, but as Mellon showed - catastrophic **** can happen.
evo8426's Avatar
That is what I did, I ran 2 tanks of 93 just in case
Old Feb 9, 2012 | 10:50 AM
Kidloco51's Avatar
I made about 60 whp from 91 to E85
Old Feb 9, 2012 | 11:10 AM
binky's Avatar
See I've also read to run a tank of pump after a few tanks of E85.
What scares me is I've also read some people injectors will gunk up after less than 20 miles, so running pump through wouldn't help in this case.
I wish we knew what the root cause was and I wish there was a way to test for it before you filled your car up.
-Bink
Old Feb 9, 2012 | 11:16 AM
bubba17's Avatar
i am also debaiting on going the e85 route myself as of what happen to mellon
Old Feb 9, 2012 | 12:57 PM
evoscott's Avatar
Well dropped her off at English today! So glad they are only min away! Can't wait to see how she runs and drives with the switch...
Old Feb 9, 2012 | 04:22 PM
tsidrift1's Avatar
I was wondering whether or not to maybe try an e85 tune when I get my car running up too. I think I am gonna stick with pump though. Maybe get a meth inj kit if I need that extra ummph.
Too, e85 might not stick around too long with the subsidzing law that has passed, or they are trying to pass. Cant remember lol. If e85 costs rise, the only people still buying it will be the guys running it for race gas at the pump. I kept this in mind as I ony have two stations in town with it now and I thought it was a pita when I had the e85 tune before.
If you do it, DEF. get a dual map.
Oh and about the injectors. When I pulled my old pte 1000s out to replace with my 1250s, they were gunked up pretty bad.
Old Feb 9, 2012 | 05:23 PM
Definitely getting a dual map tune also, never know whats going to happen with the fuel situation these days.
Old Feb 9, 2012 | 06:19 PM
blknblubkrdude's Avatar
Dual map tune is where it's at.
In my case it will be 91/116 tunes. I have no E in the area, and will have to barrel it either way.
The smell of race fuel is hard to beat, and the only thing it gives up over E is egt's and cost. I like the idea of more lubricity, higher octane, and less corrosion when using gasoline. For the amount I use it, I won't hardly notice a difference in cost between the two.
Definitely go for the E85/Gas tune if you are able.
Old Feb 9, 2012 | 07:39 PM
04_k20a2's Avatar
if use for a long period, won't the E85 eat up the fuel lines as well?
Old Feb 9, 2012 | 08:05 PM
SmurfZilla's Avatar
Old wives tale.
No.
