Starting problem, [update: ignition switch]
Old Feb 16, 2023 | 04:53 PM
WelDun1's Avatar
Originally Posted by EVO3675
Start off by cutting a small triangle out of a coke can and bend into the shape seen
Place the part into the electronic part of your switch as seen
Once completly inserted make sure it looks like the picture
After the part is placed back into the locking mech ,turn and see if there is any hangs or snags. If so you may have to trim but if there is none the you are good. Ive had mine like this for a year now and no problems
This is definitely original LoLOutta all the threads I've seen about the Ignition switch, this is the only one Ive seen on how to modify the switch to prevent replacement.
It's creative, I'll give you that much. The only problem I see is that the metal could possibly create a short after awhile. If anything, I'd say ur better off using a piece of plastic instead since there aren't any contact points in normal position. I've started my car by turning the ignition switch with my finger.
SaulHudson
Nov 10, 2017 06:35 AM
wazzelby
Mar 29, 2017 06:28 AM
lancer586
Lancer Troubleshooting
Feb 21, 2017 09:37 AM
FlashEvolution
Jun 22, 2016 08:00 AM
