AEM Wideband install?
Old Feb 16, 2012 | 12:39 PM
evoboy2012's Avatar
Does anyone have a video on how to install the wideband on evo 9?
Old Feb 16, 2012 | 12:52 PM
ajnasrah20083's Avatar
I need to a vid too.
Old Feb 16, 2012 | 12:55 PM
Vivid Racing's Avatar
It's real simple. Just pull the old O2 sensor out, and install the wideband. Run your wires to your gauge and you're done.
Old Feb 16, 2012 | 12:56 PM
Tekniq's Avatar
What part are you stuck on? Its fairly straight fwd. The hardes part for me was pushing the wire through the firewall rubber under the glove box.
Old Feb 16, 2012 | 01:05 PM
evoboy2012's Avatar
The hardest part for me is how do i start? What do i do first if someone can make a video i would appreciate it alot, I think it might be simple but i just dont want to mess anything up. And also my boost gauge does not have light on it how can i get light threw it too while iam doing this?
Old Feb 16, 2012 | 06:05 PM
SW20Mike's Avatar
Veteran: Air Force
Pretty straightforward, just did it myself in December. Only thing I had to pay a shop to do was weld the o2 bung in my exhaust, and that cost $20. You literally just run the wiring from the o2 wideband o2 sensor mounted according to AEM's instructions. Tap a power wire to the gauge and run the ground wire to a good ground source. The remaining wires are for datalogging and aren't used unless doing so. If you can't do that might wanna get a shop to do the install for you.
Old Feb 16, 2012 | 06:21 PM
awdturbo8's Avatar
It's really easy. Power wire,ground. O2 sensor plug,gauge hook ups. It's straight forward.
Old Feb 16, 2012 | 07:01 PM
evoboy2012's Avatar
there is one line that is smaller and connects on the right side of the guage and has the other end its just wire where do i connect that wire? is that a light wire or?
clubEVO93's Avatar
Pull your downpipe. Take the downpipe to a shop and have them weld in the supplied bung from aem.(cheap) remember at the three oclock angle at the end of the downpipe for the best readings. On my MR there was a rubber groumet beside the down pipe but closer to the turbo. Once that is found pop it out. Then mount your WB where you want it. go to the passenger side of the car and and take off the black covering. And then you will have to run the smaller side of the WB through becasue the side coming from the sensor is to big to fit through the hole. Then go to the top of the car find a good power sourse. I used the lower left fuse box with add a circuit and then grounded it to a screw under the driver side dash.
This is what I did https://www.evolutionm.net/forums/ev...t-gauge-2.html POST #20
Old Feb 16, 2012 | 07:07 PM
evoboy2012's Avatar
well cant i take out the stock o2 sensor and put this one in there?
Old Feb 16, 2012 | 07:22 PM
Macaroni's Avatar
If you do that you'll throw a code for rear o2 heater circuit but there's a patch to disable it in tephra 7
Old Feb 16, 2012 | 07:33 PM
4RETECH's Avatar
Here is at least so of it:
https://www.evolutionm.net/forums/ev...-wideband.html
Also, the two wires coming off are for logging too. Read the instructions as they are helpful. use the blue wire to log with a serial cable. for my use the white one just gets taped up.
Good Luck
Old Feb 17, 2012 | 01:34 AM
evoboy2012's Avatar
I need a video lol, when someone makes one they will be a HERO! hahaa
Old Feb 17, 2012 | 08:13 AM
Tekniq's Avatar
Don't take this the wrong way, but I think the reason there is no video is becase its fairly easy to install as stated before.
A video can't hurt, but I dont see one being made anytime soon.
Old Feb 17, 2012 | 09:59 PM
Macaroni's Avatar
If you need a video on how to hook up a power and a ground then you might want to either A: start researching on electrical systems, how they operate, etc. or B: choose a different hobby.
Your making this seem a lot harder than it is. What about this seems so difficult to you?
