Steering pull question...
Old Feb 18, 2012 | 08:40 AM
PearceEVOix's Avatar
This may be a stupid question but my local tuner couldn't figure it out off the top of his head either. The issue I have is when I'm driving straight (no acceleration) it drives straight, however, if I'm driving straight but give it even the slightest bit of gas it pulls to the left. The closer I get to WOT the harder it pulls. Any ideas on this? My alignment is fine btw. Any help is appreciated
Old Feb 18, 2012 | 09:39 AM
DeFog's Avatar
Is the car properly aligned or the tires chopped, over or under inflated differently?
Just for extra measures I would check suspension components in that area, wheel bearings, axle shaft, links etc.
Chances are it isn't those but it's good to be aware, most cases people never align their vehicles after such a long period of time and starts to cause issues like so.
Old Feb 18, 2012 | 10:41 AM
Yeah it was just aligned last month, and when driving out of boost its fine and straight. I'll have to check all the components out I guess. It's not life or death but annoying that I need to fight the steering a little while in boost. Anyone else have any ideas?
Old Feb 18, 2012 | 10:56 AM
sr20det91's Avatar
Is the center diff whining any? LSD issue maybe?
Old Feb 18, 2012 | 11:03 AM
Murf's Avatar
Couple of things
1 toe can do this, have it checked. However it would pull ( hands off wheel) to one side on a flat road at low speeds.
2 ( my case) bent rim. Swap wheels around ( left side to right) see if pull follows. If so bent wheel.
3 others stated above.
Old Feb 18, 2012 | 11:11 AM
Not that I can tell no, I hope it's not that haha.
Originally Posted by Murf
Couple of things
Yeah it doesn't pull unless I'm on the gas. Ill try swapping the wheels around and see what happens.
Thanks for the input you guys
Old Feb 18, 2012 | 11:23 AM
ChanseEvo8's Avatar
Registered User
There could be many things for this solution. First off check your tires, sometimes a bad tire can cause a directional pull. rotate font to back and see if it helps. the height of your car could be un even, the roads are uneven, tie rods (toe adjustment), bent or damage suspension components.
It varies alot because my integra has full suspension work, new tires and just about everything new with proper alignment(built from ground up). And still manages to pull to the right at acceleration. G/L
Old Feb 18, 2012 | 11:33 AM
OfaceGrimmins's Avatar
I'm gonna say its a motor mount. If you can heel/toe brake, you can have a tech check it for you, you'll have to slip the clutch pretty good though. Usually the rearmost (firewall side) mount goes bad first thanks to the monstrous torque these babies push. Give it a shot, see what happens.
Old Feb 18, 2012 | 11:44 AM
barneyb's Avatar
Thrust angle - back wheels pointed a slightly different direction than the fronts.
Old Feb 18, 2012 | 11:46 AM
^^ that too
I'll check in to all the above suggestions
If this happens to be the issue what can be done about it?
thanks
Old Feb 18, 2012 | 11:51 AM
Nvm looked it up thanks!
Old Feb 18, 2012 | 11:57 AM
barneyb's Avatar
thanks
If true, it is just a screwed up alignment.
barneyb
28
May 22, 2021 01:16 PM
06RedRalli
Apr 21, 2016 02:54 PM
r0xah
Jan 22, 2011 11:00 AM
jid2
Feb 8, 2006 06:29 PM
