evo 9 running rich bad gas mileage
Old Feb 21, 2012 | 03:31 PM
Antlane90's Avatar
my evo 9 is running rich before i had bad o2 sensors i replaced them im still getting the error code of a bad o2 sensor does anyone know what it can be
Old Feb 21, 2012 | 03:40 PM
eliminator 429's Avatar
More information is needed for us to help. Have you done any modifications to your car lately? You may need a retune if you did.
Old Feb 21, 2012 | 03:47 PM
Antlane90's Avatar
no i just have basics dont cold air exhausts headers and upper and lower intercooler piping
Old Feb 21, 2012 | 03:48 PM
evo8dreamcar's Avatar
Have someone read the readings from the o2 sensors. Could be a cat also.
Old Feb 21, 2012 | 04:01 PM
Antlane90's Avatar
ok thank but if it was the cat wouldnt it be the rear sensor the code pulling up is the upper sensor
Old Feb 24, 2012 | 06:35 PM
Heezayx's Avatar
Have you done a boost leak test? if not you should because that could be the reason why your running rich... i had a huge boost leak and i was running super rich. try leaning your MAF sensor too
Old Feb 24, 2012 | 08:28 PM
impact blue's Avatar
You have to make sure its an oem sensor not one from pepboys or over the counter or a used one. Also make sure that you check for boostleaks too that will make the car run like crap like Heezayx said. Then once al of that is done give it a tune up and then get it tuned. If you have a check engine light whatever its asking for get it fixed.
Old Feb 24, 2012 | 08:30 PM
Svendiesel's Avatar
Check for boost/vacuum leaks.
89turbosupra
Oct 17, 2015 03:57 PM
malac0da13
May 15, 2014 09:56 AM
Presidential18
17
May 11, 2014 10:56 PM
johnnyr55
Apr 12, 2008 06:54 PM
Tampa Evo
Sep 18, 2006 09:17 PM
