Whistling Noise plz help!
Old Feb 24, 2012 | 05:33 PM
8-BallEvo's Avatar
Ok so long story short, pulled up and parked to get something to eat. Heard no scrapes or anything. When i was leaving i go to pull out and heard some scraping. I have injen IC piping and the LICP tends to hang low and scrape sometimes so I thought nothing of it but as soon as I started to drive away I heard a kind of tea kettle noise.
I immediately thought the LICP got a pinhole leak, so i took it off put the stock one on, same thing. Took off the rest of the piping including the IC checked everything reclamped all clamps, still have the noise. I did a boost leak test and I could not reproduce the sound it was making everything sounded normal.
Checked everything twice over including the J pipe, no cracks, no holes, nothing.
At this point im completely stumped. Heard a couple of people say my turbo is dieng because it has very little shaft play (left and right not in and out)
So heres some videos of the sound it makes under boost. It definitly sounds a lot worse under boost, and with the videos its a little harder to hear while not in boost. Sorry for the long story(wasn't short after all) but im super fed up and I want this crap fixed! Any help is appreciated thank you.
BTW my mods are 3' Turbo Back exhaust with cat, INjen intake and IC piping, upper and lower, stock IC, stock evo 9 BOV, and a 3 port boost soilenoid.
http://www.youtube.com/watch?v=1_8w8...fpO55HHF4CKmAe
http://www.youtube.com/watch?v=QsN-B...fpO55HHF4CKmAe
Old Feb 24, 2012 | 05:53 PM
Manny1020's Avatar
Boost leak my friend. Get her tested.
Old Feb 24, 2012 | 05:54 PM
Manny1020's Avatar
I had the same thing it was coming from the J pipe on the stock evo9 turbo.
Old Feb 24, 2012 | 06:03 PM
MileHighX's Avatar
I have a slight whistle from a crack in my wastegate, nothing like yours though. Might be worth checking if you haven't already. Good luck man.
Old Feb 24, 2012 | 06:08 PM
8-BallEvo's Avatar
As stated before I did a boost leak test and heard no hissing or that noise =\ and I don't have a evo 9 turbo just a 9 bov
Old Feb 24, 2012 | 06:15 PM
MileHighX's Avatar
The BOV and wastegate are two diff things. Both 8 and 9 turbos have the same components just different sizes.
Old Feb 24, 2012 | 06:17 PM
8-BallEvo's Avatar
I wasn't referring to your comment milehigh
Old Feb 25, 2012 | 12:13 PM
Manny1020's Avatar
Well last time that happened to me it was my FP RED turbo, Turbine was hitting the housing. Good luck man check for shaft play on your turbo.
Old Feb 26, 2012 | 10:30 AM
8-BallEvo's Avatar
Yea there is very little shaft play with my turbo but I've pushed it to the side and turned it but didn't feel any contact to the housing. But it was a little harder to turn not exactly free spooling.
Old Feb 26, 2012 | 04:43 PM
boostless's Avatar
im sticking with boost leak...i happens when you start to see substantial boost
Old Feb 27, 2012 | 07:25 AM
8-BallEvo's Avatar
Well as of yesterday I pretty much confirmed that it wasn't J pipe. Took it off for the third time and when I put back on accidentally stripped the right bolt that goes into the turbo so know I hear a secondary leak from there. So I hear 2 leaks now both in different places so the J pipe is completely out of the question now. But now I need to either drill out that hole or put in my 9 turbo. Still need the install kit and the actuator. Ugh
Old Aug 18, 2012 | 01:47 PM
IXFTMFW's Avatar
whisle sound from passener side
Hey man did you ever figure that problem out? I have the exact same sound coming from my IX and only happens under boost. Gonna run a leak test tonight but wondering if you pinpointed it.
Old Aug 19, 2012 | 01:07 PM
8-BallEvo's Avatar
As a matter of fact I did. I ended up buying an 8 turbo with a 10.5 hot side to replace my old one and it turns out the inner turbine on my old turbo was bottoming out and grinding against a hub like thing(don't know the technical name). My opinion is that the reason it only did this under boost is because when it creates boost the shaft would move because of the pressure and cause it to rub. Good thing I changed it, if those blades would have exploded my engine would be done. Definitly suggest rebuilding or replacing your turbo.
pointblink19
Aug 1, 2016 08:22 AM
stormy11
Jul 18, 2016 03:27 PM
lancerevolution
Sep 13, 2013 09:31 PM
miked420
Northwest Region
11
Feb 7, 2006 10:34 AM
