cold start idle problem
Old Feb 28, 2012 | 07:40 PM
techghost's Avatar
What plugs are u using? I use to have this prob on another engine when using 9 range.
Old Mar 3, 2012 | 10:16 AM
uhhhson's Avatar
I'm using oem plugs with spool in up coil packs, well i did a full leak down test, boost leak, and compression and replaced the iacv nothing has helped yet, I'm going to test the injectors monday
Old Mar 3, 2012 | 10:27 AM
b16a2delsol's Avatar
What part of slc are you in? I can take a quick look at your Injector settings to see if I can help....
Old Mar 3, 2012 | 10:59 AM
nytalonTSi's Avatar
Your issue sounds like a dying fuel pump. I've had pumps die on me and had very similar symptoms. Fuel pump oring problem. Check the fuel pressure, on cold start up if you can.
And you ruled out the IAC, which would also pull this.
Have you done a boost leak test? This is a must every oil change.
I haven't really heard any failing on the evos but the BISS(idle screw on top on throttle body) has an oring on it that can fail.
But I also wouldn't overlook the tune, I've read a few threads where the car
was on SD and act like that on cold startup especially in the winter.
Originally Posted by uhhhson
this is the second tune on the car and it still does it plus my tuner tuned my buddies evo set up like mine and his car is fine
But still every car is different.
Old Mar 3, 2012 | 11:35 AM
uhhhson's Avatar
yea did a boost leak test yesterday i have a small one coming from the throttle body seal, next step is to test the fuel system, my tuner has tuned a ton of speed density setups and none of them have problems
Old Mar 3, 2012 | 11:49 AM
techghost's Avatar
Interesting, like I said this could be a dying fuel pump, may be injectors are giving up (but you don't have any prob when car is at NOT so I'd ommitt this doubt), plugs gap/heat range (but you've already verified), could be tuning issue, may be resistor pack? (But this will be my last bet)
Have u cleaned up ur TB and iacv? Do u have any cel?
ezzey
AEM EMS
11
Jan 20, 2016 08:46 PM
ezzey
Jun 20, 2015 09:14 PM
hediki12
Nov 21, 2012 09:40 AM
WTXevolution
Feb 17, 2012 10:43 PM
nothere
Feb 10, 2010 06:25 PM
