clunking sound from front end
Old Mar 1, 2012 | 12:33 PM
techghost's Avatar
Hi,
I hate this stupid sound coming from driver side area, it feels like its coming from suspension. I've got KVIII coilovers with hks camber 2 way kit.
One side is fine but this sounds comes from the other side and only when I go on speed bumps, pot holes or suddén impact on front.
Aný ideas where this could be comíng from? Shall I tighten those allens on my camber plates? Or. Could it be something else related to coilovers?
Please help I really want to get rid of this noise.
Old Mar 1, 2012 | 12:52 PM
Ginglingston11's Avatar
Originally Posted by techghost
Hi,
First and easiest thing to do is check your sway bar for cracks or broken (never seen on an Evo but possible) check bushings and links. If they all look good shake the car left to right. See if u can hear the noise your talking about. A second person would really help to target the noise if you can produce it by shaking the car
Old Mar 1, 2012 | 12:58 PM
SilverShadow03's Avatar
How many miles on these coilovers?
I had a clunking sound on both front corners and it turned out to be the top nuts on both sides had loosened...check them and re-torque them down. Worth checking out. Also check your sway bar end links for any wear and tear or for looseness. Someone else suggested I check them out too ... mine turned out to be fine...just had to re-torque the top of the coilovers.
Old Mar 1, 2012 | 09:04 PM
techghost's Avatar
What is the tightening torque for top mount camber kit allen bolts? I'm afraid to break them or slip them
Old Mar 2, 2012 | 03:23 AM
techghost's Avatar
Ok! i've sorted it out, there is a 22mm nut on top which i tighten and this noise is gone now. by the way what nut is it? the one which has soft/hard adjustment on it
Old Mar 2, 2012 | 03:27 AM
bigben's Avatar
If the tie rod end boots are tore, they tend to be noisy.
Old Mar 2, 2012 | 12:49 PM
Its the main top shock nut...check the other side while you are at it. The adjuster simply sits on top of that nut...
Old Mar 3, 2012 | 12:38 AM
techghost's Avatar
thanks.
i've just hand tightened it, i guess 10nm torque. very lightly tightened it and now this sound is gone.
this was a big nut unlike what is being mentioned otherwise (17mm or so) so i was not sure where this exactly goes to and what is it for.
Old Mar 12, 2012 | 01:42 PM
Make sure you torque it to spec....'hand tightened it' isn't gonna cut it. 10 NM is 7.3 ft lb.
Old Mar 12, 2012 | 07:50 PM
Buch's Avatar
Good info. I got this same issue on my KWs. Drivers side front. Weird.
Old Mar 12, 2012 | 11:30 PM
techghost's Avatar
^ i had the same issue, i tightened allens on camber plates and everything; in the end i found this big 22/23mm nut to be lose (the main one) so tightened it.
Will torque it today to 10nm (although this is shocking for me that a 23mm nut is tightened at 10nm)
Old Mar 16, 2012 | 12:03 PM
Look up the torque spec.
Just to make sure you understood my reply I was not saying 10NM is the ACTUAL torque spec. I was simply implying that 10NM is 7.3 Ft. Lbs and that is not very tight at all.
nukleus
Oct 28, 2015 03:30 PM
LRM1981
37
Dec 10, 2014 08:37 PM
koolzero
Aug 8, 2014 10:51 AM
gtagsr
Evo X How Tos / Installations
Jun 23, 2009 02:15 PM
shuttlegoose
23
Dec 16, 2008 04:36 PM
