Low Compression in 2 cylinders
Old Mar 7, 2012 | 05:59 PM
Pssst's Avatar
After recently fixing my starting issue(me being a total idiot mixing up the coil wires)
I did a compression test,
From left to right looking down on the motor...
1(150psi) 2(90psi) 3(90psi) 4(150psi)
What would cause this sort of compression issue? Stuck valve? Head gasket? Rings?
Hoping to have it leak down tested to further my troubleshooting, just hoping for ideas!
Thanks in advance
Old Mar 7, 2012 | 06:56 PM
EVO8STI's Avatar
id say head gasket leak between the two cylinders that have low compression
Old Mar 8, 2012 | 04:22 AM
xxthayxx's Avatar
it does sounds like a head gasket problem. any coolant/oil mixing? the leak down test will definitely give you a better answer.
Old Mar 8, 2012 | 07:02 AM
Pssst's Avatar
Alright cool, at least more then one person agrees on this then just me thank you!
There is no leaking of coolant/oil. I need to find someone who can do the test, since I dont have a compressor But thanks for your response
Old Mar 8, 2012 | 07:18 AM
WHTEVO's Avatar
I vote for head gasket as well. Do a leakdown when you can. Good luck.
Aaron
Old Mar 8, 2012 | 09:35 AM
techghost's Avatar
do a wet test, put some oil and then check compression. if this doesnt increase compression then its HG
Old Mar 8, 2012 | 12:26 PM
BlackEight's Avatar
sounds like a head gasket. Leak down test
lostsoulsevo
28
Feb 9, 2017 05:52 PM
b0yw0nder
Jun 4, 2016 06:37 PM
Runker
Apr 26, 2016 05:23 PM
ym827543327
Apr 6, 2015 07:56 PM
fabcas311
Sep 6, 2013 09:15 AM
