TBE and emissions testing
Old Mar 8, 2012 | 09:43 AM
IronPalm's Avatar
I'm looking to finally do something about my exhaust setup and was wondering what are people's general practice regarding emissions. I was hoping to go TBE instead of catback but don't trust myself to want to go back and replace the exhaust once a year to do Georgia's emissions testing.
so for the TBE users do you guys usually switch out the entire exhaust when it's time for testing? Or does anyone use or recommend perhaps a 3 inch high flow cat that can stay on the car that wonmt's sacrifice too much performance.
Old Mar 8, 2012 | 09:46 AM
JonahEVO's Avatar
I went to Emission with a turbo back exhaust(test pipe) and pass it with flying colors. All they do is plugged it in into your 0bdII port.
Old Mar 8, 2012 | 10:04 AM
PearceEVOix's Avatar
In California I was running a full TBE with test pipe and it passed everything but visual, so swapped my stock cat back in place of the test pipe and passed.
Old Mar 8, 2012 | 11:02 AM
GTijoejoe's Avatar
I'm not sure if any state with a car newer than '96 will even do an actual sniff test.
Most likely OBDII scan and visual check.
Old Mar 8, 2012 | 11:10 AM
SilverShadow03's Avatar
CA sniffs and plugs into your OBDII port.....my 03 evo got sniffed and FAILED with out of this world emission levels (bad HFC)....borrowed a friends stock exhaust and purchased a low miles oem cat and passed with flying colors (still have it for my next required sniff test).
Old Mar 8, 2012 | 05:45 PM
GTijoejoe's Avatar
Thanks for the confirmation
Old Mar 8, 2012 | 08:09 PM
alleggerita's Avatar
In my area they do OBD-II and visual for cat. Test pipe failed. I put the factory cat in the 3" turbo back and passed. Since then I have put a 100 cell cat in. We'll see what the response to a small cat below will be ....
Old Mar 8, 2012 | 08:29 PM
BluEVOIX's Avatar
When you guys say visual inspection, are they just squatting down and looking or are they using a temp gun/camera type device ?
sujinX's Avatar
i think it depends on your emissions place. here in colorado they do obd2 scan, sniffer and visual. i was looking around for cats and found the berk to be legal. i was going to get it but i got a 100 cell cat instead since i have a slip fit and not a bolt on. a cat only does so much, if your extremely modded, the cat wont help you pass, let alone a tbe.
http://www.berktechnology.com/produc...ytic-converter
visual inspection means they look down to see if u have a cat and the correct number of o2 sensors visible.
some places have on-ramp emissions testing, and they do have infrared cameras to see heat build up where its suppose to be.
