What Vacuum Hose are YOU using?
Old Mar 23, 2012 | 09:29 AM
Kracka's Avatar
Whatever black rubber vacuum line O'Reily's has.
Old Mar 23, 2012 | 10:28 AM
GTijoejoe's Avatar
vibrant silicone -same as STM I believe... buts that's more recent... usually what ever Adance carries... never had an issue.
Old Mar 23, 2012 | 12:06 PM
Thore's Avatar
Water feed line from several old toilets. Car runs like sh*t.
Would steel braided vacuum lines be a little over the top?
Old Mar 23, 2012 | 12:11 PM
n2oiroc's Avatar
yes, expensive and a pain to work with.
Old Mar 23, 2012 | 12:28 PM
ViciousLSD's Avatar
Originally Posted by EvoJoeIX
Wiper fluid line should not be used as vacuum hose
why not? I use it for the boost/vac gauge and when experimenting with the boost control lines. no problems here. its cheap, looks nice(especially the 'prestone' ones) and stronger than the OE ones
Old Mar 23, 2012 | 05:05 PM
GTijoejoe's Avatar
He says that because most likely it is not designed for high vac and pressure levels which most vac hoses are for, meaning in comparison it won't reach the same type of performance of actual vac hose.... there are differences, will they reflect to the level which you will be using it for... maybe not, but just general information.
Old Mar 23, 2012 | 05:10 PM
meckert's Avatar
Hose techniques, silicon best I have found, order the size you need in the qty you want.
Old Mar 23, 2012 | 08:21 PM
blknblubkrdude's Avatar
Thanks for all the replies gentleman!
After a bunch of research I decided to buy a bunch of hose from BoostControllers.com
It is 4mm "MAGNUM" hose, and is astronomically thick (3.2mm wall), but yet just as pliable as standard hose.
Yes I got 40 feet of it, lol:
At only $1.07 a foot, it is really hard to beat.
Old Mar 23, 2012 | 11:42 PM
ViciousLSD's Avatar
thanks. I read that as way over estimating is always better. its like building a show car that one plans to keep forever but sells it a year later
I dont even clamp my boost control lines anymore and it still works fine. at 25+ psi my intake hose has a very very high chance of popping to tell you the truth
Old Mar 24, 2012 | 01:26 PM
drewbird91's Avatar
http://www.siliconeintakes.com/index...ba4dc002ed6dba
Old Mar 24, 2012 | 01:32 PM
EvoJoeIX's Avatar
im a firm believe in use the product for what it was designed for
GTIjoejoe took the words out of my mouth
Old Mar 24, 2012 | 09:38 PM
ViciousLSD's Avatar
APRacing designs a lot of their race stuff DOT approved too
Old Apr 12, 2013 | 10:38 PM
silverevo05's Avatar
I just got 15feet from siliconeintakes.com....It's too fat to tie it down at the gm 3 port.
Will I be ok not clamping it down or are there thin clamps? I want to avoid the zip ties
Old Apr 12, 2013 | 11:00 PM
llDemonll's Avatar
use zip ties
Old Apr 13, 2013 | 04:49 AM
studioface's Avatar
I used this http://www.ebay.com/itm/121044166967...84.m1439.l2649 its 5mm ID just as the injen silicone hose replacement for the BOV and it works great and cheap too 5 bucks for 8 feet.Also if you are looking for OEM type clamps instead of using zipties get these http://www.ebay.com/itm/370455712524...84.m1439.l2649 its 7/16 and fits stock hoses perfect.
