What Vacuum Hose are YOU using?
Old Mar 16, 2012 | 05:07 PM
blknblubkrdude's Avatar
Over the past couple years I have owned my EVO, I haven't had much of a problem with my vacuum hose. Only a couple pin sized leaks that showed up during boost leak tests.
My intake is off getting ported, and instead of running straight to NAPA to get a roll, I thought I'd check to see what everybody's preferences are.
Thanks!
**3/23/12 Update**
After a bunch of research I decided to buy a bunch of hose from BoostControllers.com
It is 4mm "MAGNUM" hose, and is astronomically thick (3.2mm wall), but yet just as pliable as standard hose.
Yes I got 40 feet of it, lol:
At only $1.07 a foot, it is really hard to beat.
Old Mar 16, 2012 | 05:44 PM
Samuelwoo's Avatar
Heavy Wall, 15' 4 mm I.D from oomphlabs. A bit expensive.
http://www.oomphlabs.com/siliconhosekit-stage2.php
Old Mar 16, 2012 | 09:03 PM
sujinX's Avatar
whatever i can find that works at ACE hardware :-(
small college town... im very limited.
Old Mar 16, 2012 | 10:48 PM
fazipolska's Avatar
stock one works for me now lol
Old Mar 17, 2012 | 07:08 AM
TommiM's Avatar
Ive replaced some of mine with STM's vacuum lines they sell, excellent stuff.
Old Mar 17, 2012 | 07:27 AM
EvoJoeIX's Avatar
Silicone vac line is the way to go, a little more expensive but will last a much longer time
Thats what STM sells, fyi
Old Mar 17, 2012 | 08:57 AM
EmeryatSTM's Avatar
Thanks guys! For those of you still looking, It can be found here.
http://www.streettunedmotorsports.co...diy_clamps.htm
-Em
Old Mar 17, 2012 | 04:15 PM
My03evo's Avatar
I want to get some new vacuum line too, what is the stock line sizes? I see there's 3, 4, and 6mm....Which is used for the intake mani 3 or 4? and I assume the other bigger intake port would be 6mm? I can't spend $50 for the combo kit
Old Mar 17, 2012 | 04:18 PM
EvoJoeIX's Avatar
i wish someone or a shop offered a kit that replaces all the junk rubber factory vacuum lines with pre cut silicone lines.
that way you just pop a line off and replace with new line. its not so much the length that gives me trouble, its the diameter. i never know what diam. to order
Old Mar 17, 2012 | 04:57 PM
4mm is what the majority of vacuum lines are. I do believe there are a couple 6mm hoses also.
If I still had all the factory parts installed I truly would consider taking a couple hours to do this.
Old Mar 17, 2012 | 06:57 PM
My03evo's Avatar
Look at post #7 from Emery, click on the link and look at the hose kit, I'm assuming has enough for to replace every line....on a stock evo at least or depending on bov location and whatnot. I want to get some and going to run seperate lines to the bov to intake and turbo/mbc since someone is running everything on one line and it is hindering the response of the bov and causing stuttering/driveability issues.
Old Mar 22, 2012 | 10:03 PM
wordapp!'s Avatar
Napa or Advance hoses ftw! Been using them for years with no problems
Old Mar 23, 2012 | 08:22 AM
ViciousLSD's Avatar
$2.99 blend-in black wiper fluid hose
Old Mar 23, 2012 | 09:12 AM
EvoJoeIX's Avatar
Wiper fluid line should not be used as vacuum hose
Old Mar 23, 2012 | 09:27 AM
llDemonll's Avatar
5/32" is the same as 4mm so for those who buy from Napa / O'Reillys that will make it easy to find
