Sloppy shifter??
Old Apr 6, 2014 | 10:55 AM
dl100489's Avatar
cheak the shifter bushings going to the trans had same problum mine was hard to shift and sloppy at times
Old Jul 19, 2014 | 07:57 AM
2fast2evo's Avatar
Sorry for digging up an old thread; would the bushings be similar on earlier (1-3) Evos to the ones for the 8/9? I have a fair bit of side-to-side play in mine and want to resolve it, but I imagine that sourcing the specific parts might be tough. If they were cross-compatible, that would be great.
Old Aug 16, 2014 | 03:00 PM
FranHaus's Avatar
same thing happens to me. goes into gear fine, but i can move it all around once in gear. anyone have a fix for this?
Old Aug 16, 2014 | 04:00 PM
2fast2evo's Avatar
I actually found a potential source of the problem; I undid the shifter mechanism in the cabin and there was a loose nut on the shaft that attaches the shifter to its linkage. Basically, there was a shaft that the shifter actuates on and to hold the shifter arm onto the shaft there was a collar with a bushing in either end, tightened on with a nut. The nut appeared to have backed out after simple use and tightening it solved a lot of my slop. I'll probably still need new bushings at some point, though.
buffhulk
Mar 20, 2017 08:05 PM
Sloppy Hachi
May 21, 2016 06:48 AM
Trever007
Mar 27, 2015 11:37 PM
Metal
Dec 22, 2012 12:06 PM
RejectedWolf
20
Oct 11, 2012 10:07 PM
