Bov suppose open a little when idleing??
Old Mar 19, 2012 | 06:01 PM
auto228's Avatar
Since I can't see the inside of my stock IX BOV, but I figure my agency power 50/50 Bov open a little when the car sitting on idle, but will close fully when step on gas!
Is that normal??
Old Mar 19, 2012 | 06:11 PM
EvoJoeIX's Avatar
It is when your using too light of a spring in the bov....unless your on speed density, it will cause drivability issues
Old Mar 19, 2012 | 06:23 PM
auto228's Avatar
I turn the spring fully tight to the "hard", but it still open a little !!!!
Old Mar 20, 2012 | 04:46 AM
auto228's Avatar
Any input ??
Old Mar 20, 2012 | 07:17 AM
thedru13's Avatar
is your vac source ok. Run one vac tube from the intake to the bov..
Old Mar 20, 2012 | 07:28 AM
auto228's Avatar
Vaccum source is good , no leak!!
I did ask my friends around , they said it is normal ! It also open a little on their Tail bov when the car is sitting on idle !! I just want to confirm !!!!!
Old Mar 20, 2012 | 07:35 AM
thedru13's Avatar
my tial doesnt sound open at idle.
Old Mar 20, 2012 | 11:37 AM
sparky's Avatar
Originally Posted by auto228
Since I can't see the inside of my stock IX BOV...Is that normal??
May I recommend the pills that make your body smaller for very brief lapses of time. This is what I took when I wanted to climb around inside the BCS on my Evo. The reductive effect does not last very long however. So, you need to accomplish whatever it is that you are gonna do inside your stock DV in a hurry.
Old Mar 20, 2012 | 02:53 PM
ViciousLSD's Avatar
BOVs should be open at idle since the manifold has negative pressure/vacuum
Old Mar 20, 2012 | 03:03 PM
EvoJoeIX's Avatar
No they shouldnt, thats why they use a spring. Its to keep them shut at idle
Old Jan 11, 2013 | 03:52 PM
mc14's Avatar
Listen to this man.
Old Jan 11, 2013 | 04:00 PM
Svendiesel's Avatar
Is your BOV on a lone vacuum source? Don't T off your BOV vacuum line to other things, nothing else should get vacuum from the line for your BOV.
Old Jan 11, 2013 | 04:01 PM
fastyouth1313's Avatar
The spring inside the BOV is there to help keep it closed under boost. It's ok for it to be open a little at idle. If the spring is to tight you will get the part throttle shudder from the BOV.
Your fine my friend no worries.
Old Jan 11, 2013 | 04:31 PM
Iowa999's Avatar
Ya know. If you stop calling it a "blow-off valve," you'll get less confused about how it works. Just sayin'.
Old Jan 12, 2013 | 09:23 AM
djdnav's Avatar
WRONG.
Vacuum is what keeps it closed. If your valve is open at idle, then your valve is either damaged, or the spring isn't stiff enough.
