my afr are at 10 on idle
Old Mar 23, 2012 | 04:49 PM
JDM EVO 6's Avatar
What could it be ive tighten all hoses no leak
Old Mar 23, 2012 | 04:51 PM
twabtoxer's Avatar
have you dont a boost leak test? if not do it and go from there. what is the afr at WOT?
Old Mar 23, 2012 | 05:15 PM
JDM EVO 6's Avatar
At wot it tappers down to 11.5
Changed maf and ajusted air got it back up to 12.4 tappering down to 10
Old Mar 23, 2012 | 05:24 PM
twabtoxer's Avatar
ok.... now you said no leaks? so that means you have done a boost leak test yes?
Old Mar 23, 2012 | 05:26 PM
cfdfireman1's Avatar
Sounds like a bad O2 sensor. Any cel?
Old Mar 23, 2012 | 06:50 PM
JDM EVO 6's Avatar
Cel is on could it be on the o2 housing?
Old Mar 23, 2012 | 11:36 PM
Chef-j's Avatar
+ 1 for bad sensor. Which wideband? how long you had it?
Old Mar 23, 2012 | 11:37 PM
Chef-j's Avatar
Did you pull the code?
Old Mar 24, 2012 | 06:29 AM
could be a lot of things
I'm leaning toward a bad front O2. You don't need to replace it with stock there are a lot of choices for way less $$$.
Old Mar 24, 2012 | 06:34 AM
joseph143's Avatar
buy and lc1. if you already have the lc1 buy and new sensor. calibrate. hard wire it to the ecu for your rear o2. done and done.
okay so there are a few other things involved like tuning and stuff but you get the point
i hardwired mine in 2 years ago... calibrate every 3 months or so and haven't had a cel since
Old Mar 24, 2012 | 06:36 AM
evo8dreamcar's Avatar
check a log and see what the front o2 reads. Easy way to tell.
