Couple Questions including where to go for tuning
Old Apr 6, 2012 | 10:14 AM
TheGreatEvo's Avatar
Biggest question I have, anyone know of any tuning places to go close to Morgantown, WV. I've been looking and the closest place I found is about 4 hours away...In that case, when/if I do mods, should I just put them on, then drive it the distance just don't go WOT or would I need to install mods, then have it towed??
I'm pretty sure there is a place in Pittsburgh, but even then, that's about an hour and half drive on a good day, two hour drive with traffic. 2nd question, the BOV has been fluttering at very low rpms, so if I pump the gas at low rpms is when I hear it the most but it sounds fine WOT. I looked this up a lot and read some say it was normal as long as it sounds normal WOT and just wanted some reassurance. It's going back to the dealership to get a new clutch, new tires, polished brake calipers, and fully detailed and the dealership is about 4 hours away so I wanted to make sure I get everything fixed that it needs (under warranty) so I don't have to take the drive back up.
Thanks in advance!
Car is all stock excluding a K&N Air Filter.
Old Apr 6, 2012 | 12:27 PM
adam_79_2005's Avatar
well now a days with the wonderful WWW, you could always have a basic tune sent t you via email as an attachment, although i am not completely sure of all the grand details but if yo have a laptop, the software and i believe its the cable plug and play you could have a tuner send you a tune based on what mods you tell him you have. I'm certain others more knowledgable will hopefully chime in and give you better details, look up mellon tuning, AMS, AWDmotorsports, buschur racing, call them and ask them what all you would need to have a flash tune sent to you, good luck.
Old Apr 6, 2012 | 02:22 PM
talonspyder97's Avatar
There should be a few places around you. JS Dyno I think is one. Also Atlantic over here in MD I believe.
MRLancer05
Jul 27, 2016 03:52 PM
scheides
Mar 1, 2014 09:45 AM
Sephiron
Jan 12, 2014 06:32 AM
Ph3n1x
25
Apr 21, 2013 11:43 AM
lancerMRguy
Jul 26, 2008 03:24 PM
