High 9's Low 10's
Old Jan 21, 2004 | 09:17 PM
Joe89's Avatar
Question High 9's Low 10's
How much would youhave to spend on a VIII to get those times?
Old Jan 21, 2004 | 10:48 PM
Ree's Avatar
Ree
Yee Yee!
go to the
http://www.cardomain.com/memberpage/330510
There are some details about the car, mod list and in favorite link section link to Norris design homepage...
Old Jan 21, 2004 | 10:50 PM
robi's Avatar
If you use Buschur...
4.400.00=stage 4 with reflash Cars in the 11's
2,200.00 AEM with Buschur settings (in testing)
2,500.00 Buschur turbo Kit (finishing assembly for testing)
1,200.00 coil on plug ignition (in testing)
This should get you into the 10's
MAJOR motor work after that
Old Jan 21, 2004 | 10:56 PM
PoorCollegeKid's Avatar
Major tranny/clutch/differential work, as well... You're probably better off getting a new Z06 when they come out and modding that beast to hell and back if you want a good 1/4 mile time with very good handling. Probably less headaches in the long run.
Old Jan 21, 2004 | 11:10 PM
Paytrick C.'s Avatar
Between 15-20k, and if you don't get any deals, know people in the aftermarket/tuning bus., or don't get sponsored, about 25k.
Old Jan 21, 2004 | 11:11 PM
zlancer's Avatar
most likely around $100,000 if you want it to last for a decent amount of time. your talkin about a whole drivetrain replacement with all custom parts (and the AWD system too) to be able to handle the power to drag it into the 9's. Norris's car cost that much i think..some crazy amount.
norris designs spend $88,000 USD on one of their evo 7's and it doesn't do 9's yet. and their other one costed "Lots" according to their site. definaty not cheap to get low 10's.
Old Jan 21, 2004 | 11:31 PM
moogle's Avatar
hmmm... with stage 4 buschur u get mid 11's. If u add t3/t4 turbo doesn't that get u through the 10's or less.
Old Jan 22, 2004 | 06:14 AM
limey's Avatar
Whats norris's time? 10.2 in the 1/4?
Old Jan 22, 2004 | 06:25 AM
chuntington101's Avatar
Norris is hitting 1/4 Mile - 10.1 Secs @ 139 Mph from his website. He should be able to get lower. Previous car was running 2.5 bar, now only 2.1!
Old Jan 22, 2004 | 06:46 AM
Speedlimit's Avatar
Admin Emeritus
Re: High 9's Low 10's
You would have to strip your new EVO VIII and make it drag car; which is really a waste of the car's job description. These questions always get flamed because a little reading here and DSM websites will mine an answer. At least you didn't want low 10's and high 9's for your reliable daily driver on pump gas.
And I bid $15 to $30k which includes two of every drivetrain compoment you will break.
Speedlimit....
Old Jan 22, 2004 | 06:50 AM
maki's Avatar
norris spend $100,000 on his VII
Old Jan 22, 2004 | 07:07 AM
NOVA EVO's Avatar
You'd need...
A big honkin' turbo
Bigger FMIC
Cams
ARP studs/bolts
Built internals (Crower, JE, etc.)
Dogbox race tranny
Bigger exhaust
AEM
plus various other bits and parts
You basically have to be putting 600+ to the wheels to get into the 9s...for less $$$ than you'd spend just to make the Evo a fast drag car, you can buy an old Fox-body Mustang, build the engine/tranny/rear, and throw a big ol' Procharger on it...that'll give you 9s for about $20K or so, including the car...it won't handle worth a ****, but it will go hella ****in' fast in a straight line!
Old Jan 22, 2004 | 10:52 AM
ru4real's Avatar
Tune your engine to 400whp (not too hard), convert to FWD, then drop an identical 4G63 in the rear to drive the rear wheels, similar to that twin-engine Audi TT. 800whp!
You'll need some interesting clutch and transmission work, but it could be cheaper and easier than anything else.
Old Jan 22, 2004 | 10:55 AM
metaphysical's Avatar
Registered User
Buschur Racing could fabricate a setup that would make serious HP. The more power you make the bigger headaches you get into. Supposing you fabricated something with a air:water intercooler and ran on C16 with a huge turbo...made 700HP. Then you have to go about driving it. Having watched the AWD DSM madness before...it's going to be a different league from 10.9 to 9.7. Expect to break alot of drivetrain parts and spend 10-25K fixing them. Go to a NHRA or IDRC event and watch them break The same is true with RWD cars without a huge budget also.
Old Jan 22, 2004 | 11:21 AM
MrBonus's Avatar
1200 Dollars.
300 Wet Shot.
Clutch.
Pray.
